FS: Reproduction 914-6 GT oil filler neck |
911_2.2T |
Sep 19 2012, 08:19 AM
Newbie Group: Members Posts: 8 Joined: 4-September 12 From: Netherlands Member No.: 14,890 Region Association: Europe |
A while ago I've had a batch of 911ST oil filler necks made, and some folks asked me if I could do a 914-6 GT Oil filler neck.
So I went on the hunt for the correct Tubes for the pressure relief valve, handle for the aluminum cap, measurements etc. I've made 2 of these filler tubes and due to the work associated (and cost billed to me) I've stopped at these 2. They are done in the bare form, but need to be cleaned/sanded/blasted and coated to look good. I would like to sell them off as is in the bare shape, because I don't want to invest more time in this. They come with the vintage 86mm Aluminum Blau cap with PMB performance handel spot welded on the cap from the inside. Asking $399 shipped a piece. These are now both spoken for[i] |
911_2.2T |
Sep 19 2012, 08:21 AM
911_2.2T |
Sep 19 2012, 08:27 AM
911_2.2T |
Sep 19 2012, 08:32 AM
I also have one set left with the 86mm Alu Oil cap and a 110mm Stainless Steel Fuel Cap.
The oil cap is the period item with cork seal and come with a long (5cm) or short (2cm) reciever neck. The Fuel cap is a newer production with Rubber seal and also comes with a 5cm receiver neck. Price for this is $225 shipped [attachmentid=335 024] Attached thumbnail(s) |
twash |
Sep 19 2012, 08:48 AM
Member Group: Members Posts: 63 Joined: 16-October 04 From: camarillo calif Member No.: 2,960 |
pm sent
Norskpole |
Sep 19 2012, 10:23 AM
Member Group: Members Posts: 60 Joined: 18-April 10 From: Oceanside, CA Member No.: 11,628 Region Association: Southern California |
PM sent
911_2.2T |
Sep 24 2012, 09:35 AM
The 914-6 GT filler necks have been sold, paid and shipped.
I have the basic hardware left to make 4 more of these. For $225 shipped you get an aluminum cap, short neck, and the required pipes to build one yourself. Attached thumbnail(s) |
porbmw |
Sep 24 2012, 03:27 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
HI
I'll take one of the kits. Will send a PM to arrange getting the $225 to you, and thanks. Paul |
911_2.2T |
Sep 28 2012, 02:37 AM
All four 914-6 GT filler kits are sold.
Plenty of Alu oil caps+ receiver necks left. |
Lo-Fi Version | Time is now: 9th May 2024 - 04:28 AM |
