Slicks, Bias-ply vs radial? |
campbellcj |
May 13 2003, 10:18 PM
OK...let's say I wanted to "play" with some slicks on a 3rd set of wheels, just to begin learning what they're like. (I can't at this time run them in POC competitive events for classification reasons.)
Would I want bias-ply or radials? Are there any other vendors besides Avon who make them in "appropriate" sizes for a stock-bodied 914, i.e. 7" wheel and maybe 8.5-9" section width (similar to a 205 Hoosier DOT tire)? Thx, |
ChrisFoley |
May 13 2003, 10:26 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I think all the mfrs went to radials some time ago.
Hoosier lists a 8 1/2" x 15" slick for a 7" wheel, in addition to the 9 1/2" cantilever slick. I am pretty sure it's still a little wider than a Hoosier 205 DOT tire. I have never seen one though. |
Brad Roberts |
May 13 2003, 10:32 PM
ChrisC,
You will be hard pressed to find a slick that fits under those fenderwells. The cantilever slicks stick way the F out even though you have them on 7 inch rims. TonyC will be along shortly and know whats available.. but I'm guessing nothing. I cant even think of a GoodYear radial that will fit. B |
Tony C |
May 13 2003, 10:51 PM
Master of Fire and Metal Group: Members Posts: 273 Joined: 27-December 02 From: Bay Area, CA, USA, Earth Member No.: 25 |
There really isn't anything in the US that will work. Yes the Avons will fit, but that tire(in that size) is designed for a much lighter formula car.
The cantilever tires for SCCA prod cars are a bias-ply tire. -tony |
campbellcj |
May 13 2003, 11:06 PM
I suppose I should contact some of the major dealer/importers to verify the specs. I sure don't want to run a tire with half the load rating I need.
This is the Avon radial lineup I was eyeballing. There are several sizes that would fit my car, I think: http://www.sascosports.com/products/avon/radial.htm The Goodyear, Dunlop, Yoko and Hoosier lines are much more limited in sizes, I think. |
Tony C |
May 13 2003, 11:10 PM
Chris, I would ask them about the 190/570/15 or 190/600/15 and see what they are designed for.
The problem is that in the US none of the racing classes allow slicks in the size that you want/need so there is no demand here for them. -Tony |
Lo-Fi Version | Time is now: 19th May 2024 - 11:57 PM |
