Starting question |
Starting question |
partwerks |
Sep 23 2012, 08:39 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I was wondering if someone could help shed some light on a fickle starting question on my 2004 WRX Subie engine.
It has this fickle problem that appears to be related to being warmed up every so often. Off and on, after being warmed up, it won’t start again until a person waits about 15 minutes and it will start back up. The fuel pressure is at 40 when pump primes, and 40 when cranking over when it is acting up and not starting. My electrician advised me that when it doesn’t want to start, to spray and small amount of starting fluid at the air filter to see if it will start, thus determining if it is a fuel problem or a electrical problem. When doing that it, will start. |
lester7410 |
Oct 1 2012, 03:43 PM
Newbie Group: Members Posts: 3 Joined: 1-October 12 From: District of Columbia Member No.: 14,990 Region Association: North East States |
I was wondering if someone could help shed some light on a fickle starting question on my 2004 WRX Subie engine. It has this fickle problem that appears to be related to being warmed up every so often. Off and on, after being warmed up, it won’t start again until a person waits about 15 minutes and it will start back up. The fuel pressure is at 40 when pump primes, and 40 when cranking over when it is acting up and not starting. My electrician advised me that when it doesn’t want to start, to spray and small amount of starting fluid at the air filter to see if it will start, thus determining if it is a fuel problem or a electrical problem. When doing that it, will start. I can,t specifically address the Subie engine, but you have a fuel problem. |
76-914 |
Oct 1 2012, 03:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
are you running the original 914 tranny and starter; the original power relay board? in other woids, what's OEM and what's been Subyfied?
timothy_nd28 |
Oct 1 2012, 04:22 PM
Do you have a wiring diagram or schematic of this setup. What year is this suby engine, does it have the fly by wire setup?
benalishhero |
Oct 1 2012, 05:46 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
I was wondering if someone could help shed some light on a fickle starting question on my 2004 WRX Subie engine. It has this fickle problem that appears to be related to being warmed up every so often. Off and on, after being warmed up, it won’t start again until a person waits about 15 minutes and it will start back up. The fuel pressure is at 40 when pump primes, and 40 when cranking over when it is acting up and not starting. My electrician advised me that when it doesn’t want to start, to spray and small amount of starting fluid at the air filter to see if it will start, thus determining if it is a fuel problem or a electrical problem. When doing that it, will start. Perhaps the comma is in the wrong spot in the last phrase? If the car starts with starting fluid, you have a fuel delivery problem...... |
914itis |
Oct 1 2012, 06:10 PM
I was wondering if someone could help shed some light on a fickle starting question on my 2004 WRX Subie engine. It has this fickle problem that appears to be related to being warmed up every so often. Off and on, after being warmed up, it won’t start again until a person waits about 15 minutes and it will start back up. The fuel pressure is at 40 when pump primes, and 40 when cranking over when it is acting up and not starting. My electrician advised me that when it doesn’t want to start, to spray and small amount of starting fluid at the air filter to see if it will start, thus determining if it is a fuel problem or a electrical problem. When doing that it, will start. "My electrician advised me that when it doesn’t want to start" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 10:07 PM |
