New/Rebuilt Turn/Wiper Switch Assemblies Available? |
gollygwagen |
Sep 24 2012, 04:35 PM
Member Group: Members Posts: 88 Joined: 13-August 12 From: Highlands Ranch, CO Member No.: 14,799 Region Association: None |
Mine isn't self canceling and just has some age, are there replacements I can switch out or is this a used part only? I could work on this one, but figured I would ask first.
Valy |
Sep 24 2012, 11:42 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Mine isn't self canceling and just has some age, are there replacements I can switch out or is this a used part only? I could work on this one, but figured I would ask first. There are new reproduction available and some very expensive NOS ones. However, non working canceletion is usually related to a missing or missaligned cancel ring on the steering wheel, especially if you have an aftermarket wheel. |
Valy |
Sep 24 2012, 11:43 PM
Check cip1.com for the reproduction ones.
euro911 |
Sep 25 2012, 01:40 AM
$23. at AZ Autohaus. Verify if you have a 9-pin connector. If so, this should work:
111953513F Meyle Turn Signal Switch; With Dimmer Switch; 9 Pin Plug Connection. Click Here Look around for some other stuff while there ... free shipping on orders over $50. ... and no tax (IMG:style_emoticons/default/smile.gif) I just ordered some Toyota parts from AZ yesterday and totally forgot that I need a supply of T4 valve cover gaskets (IMG:style_emoticons/default/headbang.gif) |
Elliot Cannon |
Sep 25 2012, 10:25 AM
About 8 years ago, I replaced mine with a new unit for a 924. (With some modifications). Works great.
gollygwagen |
Sep 26 2012, 09:38 AM
Thanks everyone, I'll snap a couple pictures now that I'm back in town. Good stuff on the Autohaus parts, I'll confirm it will work with my piece.
gollygwagen |
Sep 27 2012, 08:34 AM
Here's what I took out. I'm counting 9 pins, so I'll try one of the other ones and see if I can get it to work. Hopefully it's pretty obvious how it all comes appart, I didn't look too closely.
(IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-14799-1348756469.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-14799-1348756470.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-14799-1348756471.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-14799-1348756471.4.jpg) |
gothspeed |
Sep 27 2012, 11:21 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Good thread .... (IMG:style_emoticons/default/popcorn[1].gif) ....... I'll be needing to do this soon ..... pending info learned here ... (IMG:style_emoticons/default/smile.gif)
Edit: ..... I have the same year 914 1.7 so this will be good info! |
gollygwagen |
Sep 27 2012, 11:25 AM
Good thread .... (IMG:style_emoticons/default/popcorn[1].gif) ....... I'll be needing to do this soon ..... pending info learned here ... (IMG:style_emoticons/default/smile.gif) I ordered the one from Autohaus AZ. They don't list it under 914, so it must be for something else but it looks like it will work. I'll post my experience once I get it. |
mburkhart |
Sep 27 2012, 06:44 PM
Member Group: Members Posts: 112 Joined: 3-July 05 From: Chester, MD Member No.: 4,364 Region Association: MidAtlantic Region |
I'm curious if there's a replacement for the copper horn contact on the top of the turn signal assembly? Mine has worn holes through the copper and now I hear the steering wheel grinding as it spins against the worn contact.
euro911 |
Sep 27 2012, 08:02 PM
I ordered the one from Autohaus AZ. They don't list it under 914, so it must be for something else but it looks like it will work. I'll post my experience once I get it. It's for a 73 Beetle sedan.I'm curious if there's a replacement for the copper horn contact on the top of the turn signal assembly? Mine has worn holes through the copper and now I hear the steering wheel grinding as it spins against the worn contact. You might try posting a WTB in the classifieds ... |
914Sixer |
Sep 27 2012, 09:10 PM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Whole assembly has to be replaced when contacts wear through
euro911 |
Sep 28 2012, 12:12 AM
gollygwagen |
Oct 4 2012, 07:38 AM
Got the new part and replaced it. It's really stiff compared to the old assembly and doesn't always want to self cancel because of that. Just kinda gets stuck. High/Low headlight switch is MUCH improved too.
It's a cheap piece, and you can tell it's not near as good as OEM, but for the price I'm not complaining. Just wanted to follow up on it. |
euro911 |
Oct 4 2012, 11:03 AM
Did it come with any lube on it?
Black22 |
Oct 4 2012, 11:11 AM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Part number you ordered and price from Autohauz AZ?
euro911 |
Oct 4 2012, 11:22 AM
See post #4, Mike
Black22 |
Oct 4 2012, 11:39 AM
gollygwagen |
Oct 4 2012, 02:33 PM
Yep, that's the one I ordered.
gothspeed |
Oct 4 2012, 05:47 PM
Got the new part and replaced it. It's really stiff compared to the old assembly and doesn't always want to self cancel because of that. Just kinda gets stuck. High/Low headlight switch is MUCH improved too. It's a cheap piece, and you can tell it's not near as good as OEM, but for the price I'm not complaining. Just wanted to follow up on it. Cool! thanks for the followup and info on the new part (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 09:04 AM |
