gollygwagen
Sep 24 2012, 04:35 PM
Mine isn't self canceling and just has some age, are there replacements I can switch out or is this a used part only? I could work on this one, but figured I would ask first.
Valy
Sep 24 2012, 11:42 PM
QUOTE(gollygwagen @ Sep 24 2012, 03:35 PM)
There are new reproduction available and some very expensive NOS ones.
However, non working canceletion is usually related to a missing or missaligned cancel ring on the steering wheel, especially if you have an aftermarket wheel.
Valy
Sep 24 2012, 11:43 PM
Check cip1.com for the reproduction ones.
euro911
Sep 25 2012, 01:40 AM
$23. at AZ Autohaus. Verify if you have a 9-pin connector. If so, this should work:
111953513F Meyle Turn Signal Switch; With Dimmer Switch; 9 Pin Plug Connection.
Click HereLook around for some other stuff while there ... free shipping on orders over $50. ... and no tax
I just ordered some Toyota parts from AZ yesterday and totally forgot that I need a supply of T4 valve cover gaskets
Elliot Cannon
Sep 25 2012, 10:25 AM
About 8 years ago, I replaced mine with a new unit for a 924. (With some modifications). Works great.
gollygwagen
Sep 26 2012, 09:38 AM
Thanks everyone, I'll snap a couple pictures now that I'm back in town. Good stuff on the Autohaus parts, I'll confirm it will work with my piece.
gollygwagen
Sep 27 2012, 08:34 AM
gothspeed
Sep 27 2012, 11:21 AM
Good thread ....
....... I'll be needing to do this soon ..... pending info learned here ...
Edit: ..... I have the same year 914 1.7 so this will be good info!
gollygwagen
Sep 27 2012, 11:25 AM
QUOTE(gothspeed @ Sep 27 2012, 11:21 AM)
Good thread ....
I ordered the one from Autohaus AZ. They don't list it under 914, so it must be for something else but it looks like it will work. I'll post my experience once I get it.
mburkhart
Sep 27 2012, 06:44 PM
I'm curious if there's a replacement for the copper horn contact on the top of the turn signal assembly? Mine has worn holes through the copper and now I hear the steering wheel grinding as it spins against the worn contact.
euro911
Sep 27 2012, 08:02 PM
QUOTE(gollygwagen @ Sep 27 2012, 10:25 AM)
It's for a 73 Beetle sedan.
QUOTE(mburkhart @ Sep 27 2012, 05:44 PM)
You might try posting a WTB in the classifieds ...
914Sixer
Sep 27 2012, 09:10 PM
Whole assembly has to be replaced when contacts wear through
euro911
Sep 28 2012, 12:12 AM
gollygwagen
Oct 4 2012, 07:38 AM
Got the new part and replaced it. It's really stiff compared to the old assembly and doesn't always want to self cancel because of that. Just kinda gets stuck. High/Low headlight switch is MUCH improved too.
It's a cheap piece, and you can tell it's not near as good as OEM, but for the price I'm not complaining. Just wanted to follow up on it.
euro911
Oct 4 2012, 11:03 AM
Did it come with any lube on it?
Black22
Oct 4 2012, 11:11 AM
Part number you ordered and price from Autohauz AZ?
euro911
Oct 4 2012, 11:22 AM
See post #4, Mike
Black22
Oct 4 2012, 11:39 AM
QUOTE(euro911 @ Oct 4 2012, 10:22 AM)
See post #4, Mike
Thanks Mark. I had read through the thread a while ago and just jumped to the end today! I wanted to know if it worked. Sounds like I might need one. Mine only cancels on full left or right turns, not gradual turns.
Thank you
gollygwagen
Oct 4 2012, 02:33 PM
Yep, that's the one I ordered.
gothspeed
Oct 4 2012, 05:47 PM
QUOTE(gollygwagen @ Oct 4 2012, 06:38 AM)
Cool! thanks for the followup and info on the new part
gollygwagen
Oct 5 2012, 07:32 AM
QUOTE(gothspeed @ Oct 4 2012, 05:47 PM)
To follow up further, it seems to be restricting my ability to get into the higher of the two wiper speeds and it's really stiff when signalling right and won't auto cancel even though I hear it click. The two might be related so I'll dig into it when I get back from a work trip in a couple weeks. Everything "works" just not really well. Better than it was, but not as good as it could be for sure. Turning left works fine and so does the high/low switch.
