Bolt up 160 amp Alternator Kit, "Plug and Play" |
pnewman |
Sep 28 2012, 09:19 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
(IMG:style_emoticons/default/biggrin.gif) "160 amp" Alternator (IMG:style_emoticons/default/biggrin.gif) High Amp Alternator with complete installation kit A brand new 105 amp alternator with a 160 amp Stator custom made to fit the 914 and TYPE IV VW engines. Contact me for details: Email is best. pnewman2712@comcast.net There is a core charge for your old alternator TIN. ___________________________________________________________________ I was advised that I should use a disclaimer. So here goes. Alternator Modification We all realize that modifying or upgrading your car can be dangerous. Modifying and tuning any vehicle with other than the factory approved parts can endanger your safety. No expressed or implied warranty is made as to product's suitability for any use or ability to protect the user from injury or death. The user assumes that risk. Peter Newman and/or manufacturer shall not be liable to purchaser or to any third party for any damages arising out of the purchase, installation, recommendation, or use of any product or combination of products. It is the user's or purchaser's responsibility to determine any specification that may be needed in the use of one of these products. Reminds me of all of those drug commercials. Installation: Pelican has a good page on alternator replacement. http://www.pelicanparts.com/techarticles/9...alt_replace.htm (Below are some details specific to the installation of the upgrade install kit.) Replace the cooling tin with the one that I modified for you. Install your new alternator with your new belt (provided.) Note: This alternator and fan are much bigger than your OEM unit and as such you must make sure of good clearance both at the back (power lug) and the fan in the alternator tin. It is a tight fit. It can be accomplished with the engine in but it is harder to check fan clearance to make sure that the fan doesn't rub the alternator tin. It is important to mention that this alternator unlike your oem unit has a fan and it spins very fast which does produce a sound similar to a turbo charger. You should not hear scraping noises or sounds similar to a dry bearing as this might mean that you have a fan rubbing your alternator tin. NOTE: If you have contact at the back of the alternator then you may need to adjust your alternator pivot bracket to move the whole alternator forward or aft in the vehicle. (The OEM bracket is designed to be adjusted. See pics below.) If the fan rubs the alternator tin then you may need to adjust the aforementioned U bolt, get a different size belt and or remove more material from the alternator tin. Utilize ALL of the cables that have been provided to replace your older, worn and now undersized cables. Note that I added a new ground cable that goes between your new battery negative terminal and your upper bell-housing to engine case bolt. Also for better grounding add a star washer between your alternator U-pivot bolt and the alternator. Do not reconnect battery cables until you are finished with the complete installation and have checked the alternator clearances: front (fan) and back (power bolt clearance with #2 cylinder cooling sheet metal.) Voltage Regulator: You will also need to remove your oem voltage regulator (as your brand new alternator has an integral voltage regulator.) Leaving your oem regulator in may act as a bottleneck for the system. OEM Air duct boot. Leave it in and pointed at your new alternator. Best of luck with your modifications Pete Attached image(s) |
pnewman |
Apr 18 2016, 08:19 AM
Dan, Thanks for the feedback! Turn it all on and drive! That's how cars are supposed to be! One thing that you didn't mention but I am sure is also going on is the quality of your starting. One thing that many don't see coming is the better starting. The battery is fully charged the last time that the car was turned off and with the larger power cables from the battery through the starter to the alternator as well as adding an additional ground to the bell housing in addition to your oem grounding the engine spins like a top with strong current flow and therefore better starting. All of the above was the goal of the kit. Enjoy! (IMG:style_emoticons/default/driving-girl.gif) Pete |
Jonathan Livesay |
Sep 21 2017, 10:33 AM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Dan, Thanks for the feedback! Turn it all on and drive! That's how cars are supposed to be! One thing that you didn't mention but I am sure is also going on is the quality of your starting. One thing that many don't see coming is the better starting. The battery is fully charged the last time that the car was turned off and with the larger power cables from the battery through the starter to the alternator as well as adding an additional ground to the bell housing in addition to your oem grounding the engine spins like a top with strong current flow and therefore better starting. All of the above was the goal of the kit. Enjoy! (IMG:style_emoticons/default/driving-girl.gif) Pete Just installed mine, it even improved my idle problems on '74 2.0 djet. Now both the idle adjustment on the throttle body and the knob on the ecu actually produce changes to idle speed instead of just being exercises in futility. I thought I had found all of the grounding faults, but maybe not? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:24 PM |
