gear change, stiff to get out of first |
cal914 |
Sep 30 2012, 05:44 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
have changed 3 shift bushing sliding ring's,the shifter ball socket and when changing from first to second it,s as though first gear is stuck and it makes a heavy noise getting it from first to second any one have any ideas thanks
914itis |
Sep 30 2012, 07:22 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Did you have that issue before changing the bushings?
cal914 |
Sep 30 2012, 07:46 AM
914itis |
Sep 30 2012, 08:24 AM
You may need to adjust the shifter. Here is a link for the instructions
http://www.914world.com/bbs2/index.php?sho...fter+adjustment |
underthetire |
Sep 30 2012, 09:23 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Or you could also have bad tranny mounts. Mine got much better after new mounts.
Cap'n Krusty |
Sep 30 2012, 09:31 AM
Is anything creating drag on the shaft? Like a broken, incorrectly installed, or wrong motor mount? Anything bent? Clutch cable tube intact? What year is your car?
The Cap'n |
Dr Evil |
Sep 30 2012, 09:53 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
When does your clutch disengage? At what point in pedal travel? You may need to tighten the clutch cable.
cal914 |
Sep 30 2012, 11:01 AM
When does your clutch disengage? At what point in pedal travel? You may need to tighten the clutch cable. the car is a 71 from second every gear is fine it,s like something holds it back from coming out of first.It seem's to get worse once its been driven for a while |
Cap'n Krusty |
Oct 1 2012, 08:27 PM
A '71 with the original tail shifter? Or a '71 that's had a side shifter setup installed?
The Cap'n |
charliew |
Oct 2 2012, 08:29 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I bet the clutch is dragging. Thats what I would guess on other cars.
Dr Evil |
Oct 2 2012, 09:43 AM
That is what my question was meant to tease out. Slight clutch drag will effect 1st before the others. Does it grind going into reverse?
Dr Evil |
Oct 4 2012, 06:45 PM
So, what happened? If it is not clutch drag, which would be easy to fix, then I fear you have a busted block inside your synchro ring. Not easy (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 12:50 AM |
