914/6 GT rear brakes, Ventilated brake discs 5-bolt rear |
Niklas |
Oct 1 2012, 12:57 PM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
I am building a 914/6 GT clone. I need vented discs rear ? Who sells them ? Niklas |
Niklas |
Oct 3 2012, 02:52 AM
Anyone ??
bulitt |
Oct 3 2012, 03:48 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I believe the 914-6 used a solid rear rotor. The rotor is too thin to be vented with the stock caliper. The best you can do is cross drilled, or slotted? I'm sure the experts will chime in shortly.
rotors are available from PMB porsche parts and GPR porsche parts. Look in the vendor forum for links to their sites. |
bcheney |
Oct 3 2012, 04:40 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
PMB is a great source for everything about braking with your 914. Here is one way to go.
The 914 V-Caliper kit was designed to allow teeners the use of a 911 vented rear rotor on their 4 or 5 lug cars (If you’re going to remain 4-lug you’ll need to have the 911 rotors drilled for the 4 x130mm pattern). If you’re mechanically inclined and you want to rebuild your own calipers, here’s your money saving alternative. These kits are designed to work on the 1973 through 1976 (late) calipers that use the machined caliper nose and hex bolts. The early through bolt hardware is no longer available in the States and would be cost prohibitive. Everything in this kit will work on an early caliper with the exception of the hardware. The kit includes: * (4) Caliper spacers (enough for two rear calipers) * (8) Longer 11mm hex bolts. * (8) Caliper seals. * (4) Longer brake pad pins. * (2) Rotor spacers drilled for 4 or 5-lug applications (vented rotors need to be drilled for 4-lug applications.) This application will now use the standard 1970-1983 vented rear rotor. The vented rotor will need 4mm turned off the outside edge (8mm total). You will also need a 911 rear brake caliper accessory kit to modify the 914 rear pad springs with the wider spreader. http://www.pmbperformance.com/catalog/item...563/5314821.htm |
Oct 3 2012, 06:25 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914-6 GT rotor from PMB Performance
Attached thumbnail(s) |
Eric_Shea |
Oct 3 2012, 07:14 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
GTs have vented rotors. Two models I've seen:
1. 914-6 caliper with spacers and longer fasteners. Hence the rare as hens teeth GT calipers. I have a set for sale in the classifieds but you probably won't like the price. 2. Rally modified GTs with 911 handbrakes and handbrake assemblies that used 911 rear calipers. Both used a custom offset GT rear rotor which is still available from Porsche for $250ish... each. Best bet is a 911 rear rotor with mounting ear spacers or rotor spacers under the hat. |
914werke |
Oct 3 2012, 08:00 AM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Rotor Spacers under the hat is probably best bet as the those 911 rotors can have a mm step at the inside mount surface preventing flush seating to the hub
bob |
Oct 3 2012, 09:15 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
Which rotors go with the "rare as hens teeth GT calipers"? Do you have to modify anything?
-bob |
Eric_Shea |
Oct 3 2012, 03:48 PM
QUOTE Rotor Spacers under the hat is probably best bet as the those 911 rotors can have a mm step at the inside mount surface preventing flush seating to the hub Ut uuuuh. QUOTE Which rotors go with the "rare as hens teeth GT calipers"? Do you have to modify anything? 1. Factory GT rotors @ $250.00 (which really isn't that bad when you consider you probably won't ever have to get another pair). 2. 911 Rear rotors with the following mod(s): a ) 5mm spacers under the caliper ears, or b ) 5mm spacers under the rotor hats. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:17 AM |
