windscreen/windshield, removal |
gazzar |
Oct 1 2012, 02:13 PM
Newbie Group: Members Posts: 11 Joined: 23-August 10 From: United Kingdom Member No.: 12,093 Region Association: England |
hi guys,
has anyone got any tips for getting the windscreen out without breaking it ? - and then what will i need to put it back in (1975 1.8) as i have got some rust to deal with. (IMG:style_emoticons/default/idea.gif) |
901 |
Oct 2 2012, 02:54 PM
Unregistered |
Pull all the trim .
Use a very thin peace of wire . Feed it between the rubber gooyyy stuff that seals the shield .very carefully push it threw to wear u can grab it on the out side .slowly pull it up and around the windshield fraim . Work it all the way around . Slowly ! Be extra carefullll .no do overs. No mulaginnn s . Now get two friends . One guy inside . To break the seal and push her out ,wile the two guys outside slowly lift her out . Have apace ready tp put the shield. Best to use a pare of ply ers to hold the wire as u work it around the shield. Pull the targa top , it will make it much easier . Also when u pull the wire across the bottom of the windshield , have a friend help work it across .one guy inside the car. Slow ! Slow .. (IMG:style_emoticons/default/biggrin.gif) |
gazzar |
Oct 3 2012, 10:41 AM
Pull all the trim . Use a very thin peace of wire . Feed it between the rubber gooyyy stuff that seals the shield .very carefully push it threw to wear u can grab it on the out side .slowly pull it up and around the windshield fraim . Work it all the way around . Slowly ! Be extra carefullll .no do overs. No mulaginnn s . Now get two friends . One guy inside . To break the seal and push her out ,wile the two guys outside slowly lift her out . Have apace ready tp put the shield. Best to use a pare of ply ers to hold the wire as u work it around the shield. Pull the targa top , it will make it much easier . Also when u pull the wire across the bottom of the windshield , have a friend help work it across .one guy inside the car. Slow ! Slow .. (IMG:style_emoticons/default/biggrin.gif) thanks 901- how is the trim held in place ? and what is the gooey stuff called to stick it back in after ive sorted out the rust - if i don't drop the screen ! |
901 |
Oct 3 2012, 05:20 PM
Unregistered |
Comes in tape rolls
Call your local Porsche dealer The window guys have this stuff that works well , way cheaper. Use the low priced tube stuff , it works just as good. Part number 477898o11a 924 part number 175.00 a roll From dealer Ow eeeee! When I reinstalled my windshield. Yeah right , I just had the local car windshield guy do my car. I used a rubber seal on the out side of the car . The stock trim has lill clips under the trim peace . U will see them when u pull the trim . Pulling it it very hard without damage . So be carefull. I used a peace of rubber the same size. As the stock trim , it weathers way better . Looks low key , and better . 911 style . Ing I like it cuz it dose not scratch . (IMG:style_emoticons/default/biggrin.gif) |
gazzar |
Oct 4 2012, 01:38 PM
Comes in tape rolls Call your local Porsche dealer The window guys have this stuff that works well , way cheaper. Use the low priced tube stuff , it works just as good. Part number 477898o11a 924 part number 175.00 a roll From dealer Ow eeeee! When I reinstalled my windshield. Yeah right , I just had the local car windshield guy do my car. I used a rubber seal on the out side of the car . The stock trim has lill clips under the trim peace . U will see them when u pull the trim . Pulling it it very hard without damage . So be carefull. I used a peace of rubber the same size. As the stock trim , it weathers way better . Looks low key , and better . 911 style . Ing I like it cuz it dose not scratch . (IMG:style_emoticons/default/biggrin.gif) thanks mate i feel a lot more confident pulling out my screen now, |
901 |
Oct 4 2012, 06:14 PM
Unregistered |
Comes in tape rolls Call your local Porsche dealer The window guys have this stuff that works well , way cheaper. Use the low priced tube stuff , it works just as good. Part number 477898o11a 924 part number 175.00 a roll From dealer Ow eeeee! When I reinstalled my windshield. Yeah right , I just had the local car windshield guy do my car. I used a rubber seal on the out side of the car . The stock trim has lill clips under the trim peace . U will see them when u pull the trim . Pulling it it very hard without damage . So be carefull. I used a peace of rubber the same size. As the stock trim , it weathers way better . Looks low key , and better . 911 style . Ing I like it cuz it dose not scratch . (IMG:style_emoticons/default/biggrin.gif) thanks mate i feel a lot more confident pulling out my screen now, Cheers (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 11:56 PM |
