how to remove tar from floor boards |
jimkelly |
Oct 2 2012, 10:30 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
there are lots of posts about this and i am glad i went with the heat gun method over the dry ice method, because i can not imagine the job being any easier than it was using the heat gun.
this thread is for the next guy that wonders how best to remove tar from his or her floor boards in about 1 hour. tip, get heat gun about 1 inch from floor, warm area, tar should start getting soft in a few seconds, them start getting knife under tar, and working tar off of the warmed floor panels. i still need to remove the seam sealer but the heat gun and a wood chisel seems to work ok on this material. debate now closed. Attached image(s) |
bandjoey |
Oct 2 2012, 11:06 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
You can also use the HF multitool. Took me about an hour to strip the floor with no mess
76-914 |
Oct 2 2012, 12:29 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif) What kind of tar are you replacing it with? (IMG:style_emoticons/default/lol-2.gif)
SirAndy |
Oct 2 2012, 12:45 PM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
tip, get heat gun about 1 inch from floor, warm area, tar should start getting soft in a few seconds, them start getting knife under tar, and working tar off of the warmed floor panels. I found it even easier if you have the gun a good 5" away and at an shallow angle to cover a larger area. No need to "melt" the tar, just get it pliable. Then use a putty knife to remove large patches at once. Oh, and wear a good filter mask, them fumes are no good for your brain ... (IMG:style_emoticons/default/wacko.gif) |
jimkelly |
Oct 2 2012, 01:28 PM
no need to melt - i agree
it seems that just getting it warmed up makes it want to come out (IMG:style_emoticons/default/smile.gif) with the narrow knife you can do all areas - but there certainly are many areas that a wider knife would speed things up. |
JRust |
Oct 2 2012, 01:31 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I agree on the HB multi tool with the blade attachment. The vibration with the scraper blade get's it off amazingly well. Good thread Jim (IMG:style_emoticons/default/beerchug.gif)
Lennies914 |
Oct 2 2012, 01:32 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
You can also use the HF multitool. Took me about an hour to strip the floor with no mess (IMG:style_emoticons/default/agree.gif) This tool also makes fast work of the seam sealer if you want it removed also. They are usually on sale for >$20 |
jimkelly |
Oct 2 2012, 01:36 PM
this thread started off in my mind as being a - heat gun - vs - dry ice - debate.
debate now reopened (IMG:style_emoticons/default/popcorn[1].gif) |
Randal |
Oct 2 2012, 02:09 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
tip, get heat gun about 1 inch from floor, warm area, tar should start getting soft in a few seconds, them start getting knife under tar, and working tar off of the warmed floor panels. I found it even easier if you have the gun a good 5" away and at an shallow angle to cover a larger area. No need to "melt" the tar, just get it pliable. Then use a putty knife to remove large patches at once. Oh, and wear a good filter mask, them fumes are no good for your brain ... (IMG:style_emoticons/default/wacko.gif) +1 I was thinking the same thing. Make sure you have a good mask. When I was spraying my flares the paint technician who came out to my place made a big deal about making sure you have a good mask. Like there is strychnine in paint... |
rhodyguy |
Oct 3 2012, 12:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
5 in 1 painters tool works super. stiffer than a putty knife so you can lean into the work, a pointy end for the corners, and pretty cheap.
do a search for a product called Captain Lee's Auto Spray-Strip. great open time, you'll be able to wipe the tar residue with paper towels, and not fume horrid. it will lift any finished paint it gets on so be very careful. i used it on the green car. k |
URY914 |
Oct 3 2012, 12:37 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lo-Fi Version | Time is now: 17th May 2024 - 04:28 PM |
