jack point rust, Weld or replace? |
Brandon113 |
Oct 2 2012, 04:33 PM
Newbie Group: Members Posts: 10 Joined: 17-August 12 From: Bedford, Texas Member No.: 14,818 Region Association: Southwest Region |
(IMG:style_emoticons/default/hissyfit.gif) This is the only rust I have found on the longs both sides are the same think I can just cut out the rust weld a plate in and then weld the jack plate and tube in? What do you all think the metal does clean up but the rust is way more than surface. One more think what are you folks treating the inside of the longs with that won't hurt the heater tubes......
Thanks Brandon Attached thumbnail(s) |
two-strokejohn |
Oct 2 2012, 05:48 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
I think upon closer inspection inside the long, you'll find more rust that should be repaired. If you let this go.... it can only get worse............ us east coast people can tell you horror stories about these areas.
billh1963 |
Oct 2 2012, 06:11 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I think some extensive long repair is in your future......
somd914 |
Oct 2 2012, 07:36 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Concur that there is more rust lurking in the shadows, but don't fear, it could be worse and can be repaired (IMG:style_emoticons/default/welder.gif)
Brandon113 |
Oct 2 2012, 08:35 PM
I am sure you guys are right, Though the car is solid and the door gaps are perfect but I know if you don't stop the rust it will keep going. I was hoping I could treat t he inside of the long with some kind of rust converter and not replace the long. So I guess I need to brace the door opening before I remove the long?
Thanks Brandon |
somd914 |
Oct 3 2012, 03:50 AM
There are jigs out there to brace the door, can't think of source right now...
Hopefully it won't be all that bad - mine had sections replaced, not the entire long. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:38 PM |
