Thanks Guys done deal. |
xsurfer |
Oct 2 2012, 07:50 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Thanks, got the CV joints loose with screw driver.
jim_hoyland |
Oct 2 2012, 07:59 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
xsurfer |
Oct 2 2012, 08:01 PM
I'm dropping the engine in my stock six. I've got the bolts out but the CV joints won't budge. Could they be glued/sealed? I've tapped on them with no luck. Ideas? Thanks Gene Spray PBS Blaster several times,it might take an extra day. Worked for me. Thanks, I guess this is day one of soaking. I've already got PB Blaster working. |
aircooledtechguy |
Oct 2 2012, 08:09 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
The pins between the bolts are a really tight fit. I've always used a plastic mallet to whack them. I hit them on the edge where the bolts are and alternate side to side. It usually takes around 3 good whacks, but they eventually break loose and begin to "walk" out of the pin recesses.
xsurfer |
Oct 2 2012, 08:29 PM
The pins between the bolts are a really tight fit. I've always used a plastic mallet to whack them. I hit them on the edge where the bolts are and alternate side to side. It usually takes around 3 good whacks, but they eventually break loose and begin to "walk" out of the pin recesses. Many thanks! I didn't realize there were pins. I'll give it a try tomorrow. |
Dave_Darling |
Oct 2 2012, 08:35 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If there is a gasket between the CV and the output flange, you can put a flat-head screwdriver on the gasket and tap it with a hammer. You'll kill the gasket, but you should be replacing it anyway. You can pry the joint away from the flange, as long as you're careful not to scrape up the sealing surfaces.
--DD |
xsurfer |
Oct 2 2012, 08:50 PM
If there is a gasket between the CV and the output flange, you can put a flat-head screwdriver on the gasket and tap it with a hammer. You'll kill the gasket, but you should be replacing it anyway. You can pry the joint away from the flange, as long as you're careful not to scrape up the sealing surfaces. --DD Thanks Dave! Oddly enough I just got off the phone with a friend that told me the same thing about 911 cars. Tomorrow should do it! |
Dave_Darling |
Oct 2 2012, 11:19 PM
I just did this on Sunday...
Note that not everyone believes in using gaskets in these joints. If there is no gasket, you might be able to use a putty knife or something similar, but you will have to be even more careful. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 07:09 PM |
