Fog Lamps Do Not Come On |
kbrunk1 |
Oct 5 2012, 10:47 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Newbie here..
Just started car and am checking things out. Everything seems to be working but the fog lamps. I assume all you do is pull the switch plug -- third one.... Nothing happens... Key is on.... Is there a trick or ...busted.... Do car have to be running? Thanks |
Rob-O |
Oct 5 2012, 10:54 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Fogs are off when the high beams are on. Try that first.
Mike Bellis |
Oct 5 2012, 10:57 PM
Fogs are wired to work ONLY when the low beam headlights are on. Turn on key, turn on headlights, turn on fogs...
Eric_Shea |
Oct 5 2012, 11:03 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
And if that doesn't do it, check the relay.
ConeDodger |
Oct 6 2012, 12:52 AM
Apex killer! Group: Members Posts: 23,579 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
And if that doesn't do it, check the relay. (IMG:style_emoticons/default/av-943.gif) Yea, there's that! |
Lo-Fi Version | Time is now: 8th May 2024 - 02:51 PM |
