kbrunk1
Oct 5 2012, 10:47 PM
Newbie here..
Just started car and am checking things out.
Everything seems to be working but the fog lamps.
I assume all you do is pull the switch plug -- third one....
Nothing happens... Key is on....
Is there a trick or ...busted.... Do car have to be running?
Thanks
Rob-O
Oct 5 2012, 10:54 PM
Fogs are off when the high beams are on. Try that first.
Mike Bellis
Oct 5 2012, 10:57 PM
Fogs are wired to work ONLY when the low beam headlights are on. Turn on key, turn on headlights, turn on fogs...
Eric_Shea
Oct 5 2012, 11:03 PM
And if that doesn't do it, check the relay.
ConeDodger
Oct 6 2012, 12:52 AM
QUOTE(Eric_Shea @ Oct 5 2012, 09:03 PM)
Yea, there's that!
