Master Cylinder Forgot to Install Copper Washers under Feeder Lines |
kbrunk1 |
Oct 6 2012, 05:33 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Was cleaning up and found the two copper washers that go under the two lines from the brake fluid holding tank.
How bad did I screw up? I do not believe this is on the pressure side of the master cylinder. Thanks |
mepstein |
Oct 6 2012, 06:15 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It's your brakes. Do it right.
okieflyr |
Oct 6 2012, 06:30 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Did you use new washers on the banjo pressure fittings? There should be some there on the top and bottom of the fittings. The feed lines are a tight slip fit into the rubber grommits on top of the master cylinder.
DBCooper |
Oct 6 2012, 07:24 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Yeah, I don't think there are washers in the feed line, no pressure, no need for them. Copper is for crush washers, for metal fittings.
Cap'n Krusty |
Oct 7 2012, 09:16 AM
Well, there ARE washers in the fluid inlets, and you should put them in there.
The Cap'n |
Lo-Fi Version | Time is now: 19th May 2024 - 12:58 PM |
