Tire Recomendation Sizes, Stock 2.0 Fuchs, street driving |
hot_shoe914 |
Oct 6 2012, 07:37 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Okay, I am tired of trying to find what I am looking for in the old threads. I need new tires for Betsy and I run 205/50/15 on my other teeners. I am afraid this will have her sitting too low for the towbar brackets that I have drug a few times already with 195/60/15s. Front struts are shot and bottomed out so new struts will probably stop that but I want a wider tire without going too low profile. I have decided to just keep her as a street driver and no ax so what say the masses? Which tire size would you suggest? (IMG:style_emoticons/default/confused24.gif)
JRust |
Oct 6 2012, 07:57 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I think you can run 195/70/15's for the correct ride eight. I'm not positive though (IMG:style_emoticons/default/confused24.gif) Might be 195/65/15's
CMONNETT |
Oct 6 2012, 08:26 PM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
205/60/15 been using that size for 15 years.
hot_shoe914 |
Oct 6 2012, 08:29 PM
tod914 |
Oct 6 2012, 08:35 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
http://www.vredestein.com/car-tyres/summer/sportrac-3/sizes/
This is a real nice Summer tire you can get in 195 65 15. Had them on my 73. Was very happy with them. |
steuspeed |
Oct 6 2012, 08:39 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I just went through this with my car. Had my195/65/15 Pirelli P6000 High Performance Summer tires slashed at the beginning of the summer. I replaced them with 195/65/15 Bridgestone ER960AS Ultra High Performance All Season tires. These were the highest rated tire in this size on Tire Rack. I hated them right out of the gate. They felt like I was driving on marsh mellows. Looked like they should be on a Taurus.
http://www.tirerack.com/tires/tires.jsp?ti...S+Pole+Position I decided against the P6000s since there were so many terrible reviews plus over double the price. However, going back I noticed that most of the Porsche guys liked the tire a lot. The big heavy AUDI's were having lots of problems with them. It is also a Porsche spec tire. Light weight at 18lbs. These tires were much stiffer with almost no lean on my car. Ride was jerky over any bumps, but it was all smiles with a go-kart feel around corners. After tons of searching on the net looking for the ultimate combo of light weight tire and wheels I purchased a set of Dunlop Direzza Sport Z1 Star Specs in 195/55/15. This tire is about 1.5" shorter, but not the 2" shorter that a 205/50/15 provides. I bought 4 of the last availible at a lower load/weight rating of 18lbs. Now they only have the 19lb version for sale. They feel a bit softer than the P6000s, but there is more grip availible. This may improve as the tread wears down from full depth. (My Pirelli's were probably about half gone.) The ride is more comfortable. There is more acceleration, since it is a smaller diameter tire. The car sit about 5/8" lower than before. RPMs while freeway cruising are up 200-300 rpms. I'm rarely on the freeway, so this is working out fine for me. The car looks great sitting lower, but I am scraping on my driveway where I was not before. The only way to get back to ~25" diameter tires is to go with a 16" wheel and 205/55/16 tires. There is a better selection of tires in this size, however the weight of the tire+wheels is going to excede the Fuch+18lb combo by a fair amount no matter what you choose. I was tempted by these 16" VTO wheels as a possible solution, but at a weight increase. http://64.27.130.204/?portfolio=16x7-class...silver-4x130-35 |
steuspeed |
Oct 6 2012, 09:01 PM
That Vredestein is an interesting tire. Guigaro tread pattern looks cool, but lots of noise complaints in the reviews.
This Eagle GT might be what you're looking for in a 205/60/15. http://www.tirerack.com/tires/tires.jsp?ti...T&tab=Specs |
hot_shoe914 |
Oct 6 2012, 09:55 PM
That Vredestein is an interesting tire. Guigaro tread pattern looks cool, but lots of noise complaints in the reviews. This Eagle GT might be what you're looking for in a 205/60/15. http://www.tirerack.com/tires/tires.jsp?ti...T&tab=Specs Thanks for all your help. I too was considering the Direzza. Also I loved the Eagle GT back in the early 80s and was considering them also. |
mittelmotor |
Oct 6 2012, 09:57 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
A 195/65-15 gives plenty of clearance. Here's a profile pic shortly after I bought my car. I believe the tires are Dunlop SP4000s (?).
Attached image(s) |
steuspeed |
Oct 6 2012, 10:27 PM
The Eagle GT was my second pic behind the Bridgestone, since they both come in a 195/65/15 as well. Heads up, the Bridgestone beat the Eagle GT across the board on TireRack surveys. Looking back, the GT may be a better performance tire. Opinions depend on the car and driver. It sure has better looks. TireRack has a $40 rebate going on a set right now if that puts you over the edge.
Ian Stott |
Oct 7 2012, 06:40 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I put a set of Bridgestone Potenza's 205/60 15's on my 73 2.0 last year and am very happy with them. Clearance issues are not huge but I am always careful when approaching speedbumps or steeply angled driveways as I have a front spoiler. Speedometer not off much with 205/60's, not enough to worry about anyway, as I'm always calculating my speed in my head as we are in Km in Canada and my speedo is in miles. Good luck with your choice.
Ian Stott Moncton Canada |
falconfp2001 |
Oct 8 2012, 04:59 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I used the tire size calculator here on the World and I came up with 205/65 15 being the closest to stock tires size which I run. The width is also nice and it barely fits under the rear fenders but will not get cut. I think it just misses by 1/4 inch. I was able to price them out for less than 80 a piece.
kbrunk1 |
Oct 8 2012, 06:06 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
I used the tire size calculator here on the World and I came up with 205/65 15 being the closest to stock tires size which I run. The width is also nice and it barely fits under the rear fenders but will not get cut. I think it just misses by 1/4 inch. I was able to price them out for less than 80 a piece. Newbie here....I am assuming the 65 number is the height? So tires can be: 185/65/R15 195/65/R15 or ?? 205 185/60/R15 195/60/R15 ??? |
jimkelly |
Oct 8 2012, 06:44 PM
kbrunk1 |
Oct 8 2012, 10:29 PM
OK Now we have
165/80 R15 185/70 R15 185/65 R15 195/65 R15 205/60 R15 If you are looking for economy and regular street driving then is the 185/65 R15 a good size? |
johannes |
Oct 9 2012, 05:06 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
As I wrote earlier 185/65 is very popular. The size with the largest offer and the one you will have the cheapest tires.
On theese pictures you can see how they look on the car. 195/65 would be my second choice. They are larger but you won't find all tires in this size (IMG:http://www.914world.com/bbs2/uploads_offsite/i46.servimg.com-5409-1349780797.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i46.servimg.com-5409-1349781033.1.jpg) |
blitZ |
Oct 9 2012, 08:56 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I've been using Kumha Ectas ASX. They come in 205/55 15 and have two keep rain grooves. Just another sized to consider.
http://www.tirerack.com/tires/TireSearchRe...ufacturer=Kumho |
rhodyguy |
Oct 9 2012, 09:39 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
a non directional tire like the ZEXIUS Xi326 in 195/60-15 is a good fit on 5.5" wheels and should eliminate rub issues . reasonably inexpensive, fairly quiet, and usually perform well all conditions. hot/cold/wet/dry. you can corner to corner rotate them as opposed to f to r only. use the money saved to invest in new f strut and r shocks.
k |
rnellums |
Oct 9 2012, 09:49 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Shoe, I have 195/65 Eagle GT's on mine and like them.
Rear: Attached thumbnail(s) |
turk22 |
Oct 9 2012, 10:45 AM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
OK Now we have 165/80 R15 185/70 R15 185/65 R15 195/65 R15 205/60 R15 If you are looking for economy and regular street driving then is the 185/65 R15 a good size? All, what impact do these various sizes have on the speedometer readings? Which size, (of sizes that are commonly available), would have the least impact on the speedometer? thx, Turk |
Lo-Fi Version | Time is now: 18th May 2024 - 02:24 PM |
