Which distributor to use |
Harpo |
Oct 7 2012, 06:08 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have two distributors JFUR4 0231167049 113905205AJ JFUD4 0231174005 022905205F One is from a 1.7L and the other is from a 1.8L. Which one should I use? I would like to upgrade the points to something more modern. I would like it to be self contained so I would preferr not to use the crane optical. It would seem that pertronics is no longer in business. However hot spark is. I'm leaning towards hot spart unless there are compelling reasons why not to Thanks David |
Black22 |
Oct 7 2012, 11:55 AM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Depends on if your running carbs of FI.
Since when is Pertronix out of business? I just looked up their website. All looks ok there. (IMG:style_emoticons/default/confused24.gif) |
Oct 7 2012, 11:59 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The first one is actually from a VW Type I. The "113" part number gives that away. The 914 distributors started with "022" or "039". Possibly "021" as well.
The 022 905 205 F is a later 1.7 914 distributor. It should have FI "trigger points" in the base, look for a three-conductor plastic plug. If you're running D-jet EFI you will need the trigger points to work, so this would be the obvious choice. Are you running carbs? Aftermarket EFI? Stock 1.7 or 2.0 D-jet? Stock 1.8 L-jet? Something else? --DD |
Harpo |
Oct 7 2012, 12:14 PM
Sorry for not clairifying that. There will be carbs on my 2056.
Thanks DAvid |
dirk9141973 |
Oct 7 2012, 12:17 PM
Unregistered |
(IMG:style_emoticons/default/smile.gif) I went with CB mega spark II kit with duel 40 engine 2056 easy to install only issue is sheet metal tins need to modify
Lo-Fi Version | Time is now: 8th May 2024 - 03:02 AM |
