Harpo
Oct 7 2012, 06:08 AM
I have two distributors
JFUR4
0231167049
113905205AJ
JFUD4
0231174005
022905205F
One is from a 1.7L and the other is from a 1.8L. Which one should I use? I would like to upgrade the points to something more modern. I would like it to be self contained so I would preferr not to use the crane optical. It would seem that pertronics is no longer in business. However hot spark is. I'm leaning towards hot spart unless there are compelling reasons why not to
Thanks
David
Black22
Oct 7 2012, 11:55 AM
Depends on if your running carbs of FI.
Since when is Pertronix out of business? I just looked up their website. All looks ok there.
Dave_Darling
Oct 7 2012, 11:59 AM
The first one is actually from a VW Type I. The "113" part number gives that away. The 914 distributors started with "022" or "039". Possibly "021" as well.
The 022 905 205 F is a later 1.7 914 distributor. It should have FI "trigger points" in the base, look for a three-conductor plastic plug. If you're running D-jet EFI you will need the trigger points to work, so this would be the obvious choice.
Are you running carbs? Aftermarket EFI? Stock 1.7 or 2.0 D-jet? Stock 1.8 L-jet? Something else?
--DD
Harpo
Oct 7 2012, 12:14 PM
Sorry for not clairifying that. There will be carbs on my 2056.
Thanks
DAvid
dirk9141973
Oct 7 2012, 12:17 PM
I went with CB mega spark II kit with duel 40 engine 2056 easy to install only issue is sheet metal tins need to modify
