Pertronix Ignition, Dwell angle tune up question |
steuspeed |
Oct 7 2012, 01:13 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Getting into my first tune up I checked the ignition dwell and it reads a pretty steady 41 through the rpm range. Engine is warm after a drive. Spec is 44-50. I pop the cap and whoa, someone had installed a Pertronix on this car. So is the dwell angle okay? Any adjustments to make here?
Java2570 |
Oct 7 2012, 02:17 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Getting into my first tune up I checked the ignition dwell and it reads a pretty steady 41 through the rpm range. Engine is warm after a drive. Spec is 44-50. I pop the cap and whoa, someone had installed a Pertronix on this car. So is the dwell angle okay? Any adjustments to make here? With the Pertronix installed, dwell isn't adjusted anymore. As long as your Pertronix unit has the specified gap between the magnet sleeve and the unit, you are good to go. The Pertronix comes with a plastic gap feeler but I don't remember what it's set at now; you should be able to find out on the Pertronix website. |
Lo-Fi Version | Time is now: 8th May 2024 - 10:39 PM |
