Heat Exhanger Repair Question, Taking out the dents and cleaning up the pipes |
able2222 |
Oct 8 2012, 09:18 AM
Newbie Group: Members Posts: 30 Joined: 29-July 09 From: Austin, TX Member No.: 10,621 Region Association: None |
I have a pair of SS heat exchangers that are in pretty good shape with the exception of the passenger side header portion just below where they attach to the heads have moderate dents in them. I'm wondering if a muffler shop could put a exhaust expander in the pipe and press the dent out from the inside? Its only about four inches or so from the end of the header but I was concerned with bending stainless steel, would it press out or crack? Anyone tried something like this?
While I have your attention, what is the best way to clean up the pipes? I used oven cleaner on the heat exhanger shell and it looks good, what do you use to get the crud off the pipes? Wire brush? Maybe a scotch pad? Thanks for any responses. |
jls914 |
Oct 8 2012, 09:28 AM
Newbie Group: Members Posts: 8 Joined: 23-August 12 From: wendell, NC Member No.: 14,842 Region Association: None |
If you use a wire brush, make sure it is a brand new brush for stainless steel. A carbon steel brush will damage the stainless steel and cause rusting. As far as the dents, I am not sure if a muffler shop can do it. Be careful not the round out the inlets. Goodluck.
jimkelly |
Oct 8 2012, 10:32 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i've used scotch pad and WD40 - then some fantastic to get the WD40 off.
if you dents are minor - i'd leave them alone. show us some pics of what you are talking about - we love pics : ) |
rhodyguy |
Oct 9 2012, 09:17 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the dents in the casing will not restrict the exhaust gases. while cleaning them flush the inside of the hes prior to install. it will help with the 'oily' smell when you start warming the interior.
Lo-Fi Version | Time is now: 9th May 2024 - 12:09 AM |
