| 7391420 |
Oct 22 2012, 10:29 AM
Member ![]() ![]() Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
Folks with Carbs,
Do you run 1 filter or 2? I found 2 on my project car, I'm inclined to remove one but what do you guys do? My feeling is that one filter should be enough, and I'd rather have fewer points where a leak could start |
| mikey63 |
Oct 22 2012, 11:33 AM
Member ![]() ![]() Group: Members Posts: 133 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California
I run three...one before the pump and one before each carb. So far the carbs have not had any junk in them!
| 7391420 |
Oct 22 2012, 01:36 PM
is there a down-side of multiple filters?- IE increased drag?
| mikey63 |
Oct 22 2012, 03:13 PM
I've never noticed any problems or draw backs with my multiple filters.
| 7391420 |
Oct 23 2012, 06:38 AM
Thanks!
After working through it last night, I realized that the second filter in some ways made it easier when running the hard line through the chassis. Now I have two filters after the pump, so I need to chase it back and see if the PO put a filter between the tank and pump. The good news is that I know the gas flowing freely from the tank to the lines where the filters are because I was able to drain the tank from them.. |
| hot_shoe914 |
Oct 23 2012, 06:51 AM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I run three...one before the pump and one before each carb. So far the carbs have not had any junk in them! (IMG:style_emoticons/default/agree.gif) Same here. |
| gothspeed |
Oct 29 2012, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I like that 3 filter idea ... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 31st October 2026 - 07:47 PM |
