> new clutch disk..., replce all or possibly just disk
Hine62
post Oct 22 2012, 03:50 PM
I need to put a new clutch disk in my 914. Can I just upgrade to the 911 six spring or do I need to replace the pressure plate also? (Bearing will be replaced too.)
Hine62
post Oct 22 2012, 04:02 PM
any self respecting mechanic is going to R&R them as a unit. And I don't blame them. Recalls are a bitch. That being said I did it. In fact, I done worser than that. I put a used disc in my white one 3 yr's ago. Then again I don't horse my clutch. I drive my car hard but I don't need much from a disc in an 88hp 2000lb car. (IMG:style_emoticons/default/beerchug.gif)
mr914
post Oct 22 2012, 04:49 PM
914 Hillbilly
Depends on the usage, and how good of a driver you are..
I've been using the same pressure plate for20 years...
Seem to go thru more core motors than clutches... W/ 2-4 track days per yer
Look for wear, grooving on the p plate blur hot spots on the clutch or pplate
Then it's a matter of, if you fix it yourself (IMG:style_emoticons/default/smash.gif) or pay someone else...
If you are a checkbook jockey, Payton put the whole kit in.
You do it yourself... Think, it only takes a couple of hours to swap one out
That is, if you know what you are doing and you don't have to DPO...
Hine62
post Oct 22 2012, 05:08 PM
My dad's a mechanic and said just replace the disc. Can I upgrade to the six spring 911 disk? money is going to be tight because of the hell hole repair that is being done soon... (IMG:style_emoticons/default/sad.gif)
JamesM
post Oct 22 2012, 10:57 PM
QUOTE(Hine62 @ Oct 22 2012, 03:08 PM) *
I have installed a used pressure plate before... wont do that again.
Last 2 times I have ordered "914" discs they have showed up with 6 springs
rhodyguy
post Oct 23 2012, 10:26 AM
add a new throwout arm pivot clip, the ball cup bushing(recessed in the throwout arm), and the 2 plastic throwout bearing retaining pieces to your parts list.
- Lo-Fi Version Time is now: 9th March 2026 - 09:16 PM
