first gear, it is a bitch sometimes |
johnpierre |
Oct 26 2012, 12:58 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hey everyone
is it just me or does any one else have a difficult time selecting first gear when the car is at a stand still. if the stop permits, i.e. a stop sign, or a traffic light that is just about to go green and i am rolling i can put it in 1st no prob, but if i am at a stop light with other car and waiting a while, in neutral and try to engage 1st gear it does not seem to want to move in to place with any kind of ease. it is really bumming me out. makes me feel like a 16 year old just learning how to drive. the trans and gear shifting is tight and without issue, so i don't thing there is a issue mechanically, but am i missing something or is this just a characteristic of this 914 transmission. i have already done to much "if (IMG:style_emoticons/default/hissyfit.gif) you can't find it, grind it." |
dlestep |
Oct 28 2012, 12:08 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
I've never had a problem engaging 1st, in either of my 914s.
By habit, I always pull it into 2nd prior to engaging 1st. Double clutching and matching rpms between engine and non-syncro boxes from the past. Secondly, during a lubrication study in the late 90s, gear oils that touted substantial boundry layer, inhibited flat face syncro engagement. It is the nature of the beast, as far as the syncros are defined. Remember, 1st and Rev are locked out of the 2nd through 5th pattern. 1st was only intended for moving off, as with the original 901 transmission. As a last note, if your clutch adjustment is incorrect and allows the clutch to move too far forward, (does your clutch pedal touch the forward bulkhead with a click and you feel a little chatter), then your clutch pedal is moving too far forward, which also inhibits proper engagement. Put the pedal-board back and adjust the clutch pedal stop. That may help your problem a little, but as with all things mechanical, it may only be one third of the problem. If you are running a four puck disk and a heavy pressure plate, you may want to change back to a stock type disk with the heavy pressure plate. Even on its' best day, the four puck sucks as a streetable disk. Lightened flywheels used on the street have their problems as well. I'm not sure if you are running either of the previous mentioned aftermarket clutch components. I just added them in respect to their involvement in 1st gear engagement problems, as well as a maladjusted linkage, or incorrectly positioned shifter plate. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:32 PM |
