FS: FI components, * Featured Item * |
914werke |
Oct 26 2012, 11:11 AM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So a few folks had asked about piecing out the late 2.0L kit I have available,
but rather than do that I have a bunch of other components Ill offer separately. (IMG:style_emoticons/default/smile.gif) Brain for a 74 2.0L? $60 TB for a 73 2.0L SOLD 2.0L Intake runners (any yr) $40 Plenum 73-74 2.0L SOLD Plenum 75-76 2.0L $50 wiring Loom for a 1.7L SOLD Oil Fill Tower w/PVC (73-74 DJet) SOLD Flashback valve (73-74 DJet) SOLD MPS for a 73 1.7L $150 Distributor (w/trigger points) for a 73 1.7L $100 Fuel Pressure Regulator (any Djet) $25 Stacked elbow connector & connector 2.0L SOLD Thermotime sensor 75-76 2.0L $30 Auxiliary Air Regulator (Djet) $75 Injectors 2.0L $20 per used, $50 per refurbished (Witchhunter Performance is my neighbor) Djet Brain Bracket SOLD Cold Start Injector $25 EGR mount (late 1.8 & 2.0L) $15 Air injection spider pipe $30 Injector clamps $9.14 Throttle Body gasket $9.14 1.8L TB w/TPS $50 L-Jet Air Horn SOLD Fuel Rails (All) $15 pair L-Jet Cold start injector $20 L-Jet Fuel Pressure Regulator $35 1.8L Plenum SOLD 1.8L ECU $60 2.0L TPS (all yrs) $30 1.8L FI harness $60 1.8 AFM $60 EGR valve (late) $40 EGR piping 2 (late) $15 EGR piping 2 (late) $15 Fuel Tank Fittings $30 Theres more as well... (IMG:style_emoticons/default/wacko.gif) |
Java2570 |
Oct 26 2012, 01:23 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
PM sent on 74 brain
02loftsmoor |
Oct 26 2012, 02:05 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
air Plenum and the Throttle body.. 76244 zip
02loftsmoor |
Oct 26 2012, 06:43 PM
PM sent on the air box and throttle body
Gint |
Oct 27 2012, 04:29 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Pm on its way Rich.
Gint |
Oct 30 2012, 06:45 AM
Oct 30 2012, 06:49 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'll take the 1.7 wire loom. Thanks, mark
914werke |
Oct 30 2012, 08:31 AM
Hello... Yes/no/piss off, anything? (IMG:style_emoticons/default/biggrin.gif) Sorry busy week, Pm'ed |
914werke |
Nov 1 2012, 11:55 AM
(IMG:style_emoticons/default/icon_bump.gif) Updated!
914werke |
Nov 9 2012, 12:21 PM
914werke |
Nov 13 2012, 11:16 AM
914werke |
Nov 21 2012, 02:37 PM
Items added (IMG:style_emoticons/default/smile.gif)
914werke |
Dec 1 2012, 06:57 PM
hotlanta914 |
Dec 11 2012, 08:12 AM
Newbie Group: Members Posts: 21 Joined: 15-July 06 From: Atlanta, GA Member No.: 6,438 |
I will take the stacked elbow connector - PM your PayPal address and I will make payment today - thanks Brian |
hotlanta914 |
Dec 11 2012, 08:16 AM
I will also take the D-Jet brain bracket if it is still available - thank you - PM me with total and shipping
Gint |
Dec 11 2012, 09:48 AM
Mr. Hotlanta (and any one else for which this applies)
You do not have to continue quoting the same post that has a gajillion pictures in it. A simple "Reply" or "Fast Reply" works fine and will not quote the entire post, pictures and all. In a classified ad, I think everyone knows what you're referring to without re-quoting the same stuff over and over again. Ordinarily it's not a problem, except when the reply your quoting has lots of pics in it. Then the pics are just repeated throughout the entire thread and it becomes very hard to read. I trimmed the ones that were in this thread already. Thanks. Back to your regularly scheduled chaos. |
914werke |
Dec 11 2012, 02:20 PM
Thanks Gint!
CG-914 |
Dec 11 2012, 02:41 PM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
PM sent on Stacked elbow connector 2.0L
Black22 |
Dec 11 2012, 03:32 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Is the 1.8 harness a 6 pin AFM or 7 pin? This would be the second largest black connector. In the picture you posted, it is overlapping the brain connector.
I'm interested in it if it is 6pin. |
914werke |
Jan 10 2013, 12:38 AM
Mike did I ever get back to you on this?
Lo-Fi Version | Time is now: 8th May 2024 - 06:06 PM |
