Cheesehead Flat head Screws and Washer question |
Steve73 |
Oct 26 2012, 10:56 PM
Photographer/Shade Tree Mechanic Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
Hi,
I just ran my old screws for my engine tin through a die and cleaned them up. I'm sure it better to use them than hardware screw for originality but what about the original washers, they are near impossible to clean and many are badly pitted and warped. Can I get exact replacements from my Loca Ace Hardware or is that heresy. Wanted to ask before I started buttoning everything back up. BTW where can one get a good Flathead screwdriver for cheese head screws. I've found that my impact hammer bit works perfectly, but what is everyone else using? Stephen |
Bob L. |
Oct 27 2012, 09:43 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
There are some members/vendors who sell new replacement hardware. Check the vendor section. At least one of the major (unmentionable) 914 parts suppliers has them too. I got a set, nice and shiny. I do think they don't put enough in the set to replace all of them. IIRC the set I got could use about 5-7 more pieces to be fully complete for tins and air shroud. Don't assume any "kit" will be everything you need.
It takes a pretty beefy screwdriver to fill the slot and not want to slip out. Ones with grooves across the faces(both sides) of the flat head grip even better. Sears has good ones. |
A&PGirl |
Oct 27 2012, 11:41 AM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
Sent you a PM.
Lo-Fi Version | Time is now: 6th May 2024 - 12:32 PM |
