LSD, cheep but hard way |
sixnotfour |
Oct 28 2012, 08:37 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
904 /aluminum case 901 ZF limited slip.
My buddy had this lying around , it wont work in the 914-901... Well to much time and little cash.... First the drive flange adapters= Done Second bearing sleeve and spacer. zf uses 45 mm bearings, 914 are 50mm and is about 12mm narrower. Attached image(s) |
914werke |
Oct 28 2012, 09:32 PM
"I got blisters on me fingers" Group: Members Posts: 10,041 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ok maybe Im dense but what are we looking at here?
Just an quick peak at the OE LSD elements that happened to be available for Pics? |
sixnotfour |
Oct 28 2012, 10:00 PM
My buddy was going to sell the early ZF LSDiff, but I told him I can make it work. equals cheap posi. for his 914-6
I made the the brown adapter discs and the alum. shields, so it will bolt up to the 914 CV's and no gaskets. Thats All |
Randal |
Oct 29 2012, 08:00 AM
My buddy was going to sell the early ZF LSDiff, but I told him I can make it work. equals cheap posi. for his 914-6 I made the the brown adapter discs and the alum. shields, so it will bolt up to the 914 CV's and no gaskets. Thats All How did it work when installed in the 901? Nice work by the way! (IMG:style_emoticons/default/biggrin.gif) |
sixnotfour |
Oct 29 2012, 08:38 AM
Worked fine, old school .. low horsepower..and had nadella axles.. I am working on the bearing adapters now.
Randal |
Oct 29 2012, 12:44 PM
sixnotfour |
Oct 29 2012, 01:05 PM
Vintage Racer, spare gearbox , His other Box has a Guard LS
gms |
Oct 29 2012, 08:48 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Interesting Stoddard used the 904 style in my GT, I will have to post some pix
Van914 |
Oct 30 2012, 04:11 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
I know where one is for sale, not cheap.
van914 |
sixnotfour |
Oct 30 2012, 12:04 PM
wingnut86 |
Oct 30 2012, 12:36 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
That's some real nice carving.
what did you use to make your parts? Da Macheen? |
sixnotfour |
Oct 30 2012, 02:47 PM
Old hercules lathe and a bridgeport. material is 17-4 SS HT to h900
Middlefour |
Oct 31 2012, 04:34 AM
Newbie Group: Members Posts: 42 Joined: 1-December 04 From: Northamptonshire UK. Member No.: 3,199 Region Association: None |
Hi from across the pond. I would be interested to know how many of you have an LSD fitted? My 1970 1.7 has a factory fitted one, the first owner in the USA did a lot of what we call autotest I think you call them slaloms. I know that in the UK my car is the only 4 cylinder with a factory fitted LSD, and possible the only 914 of any sort with a factory fitted one. Be interested to find out.
pcar916 |
Oct 31 2012, 08:07 AM
You might want to start another thread with this question and perhaps a poll if there isn't one already... I haven't looked. That said.
Your autotests are probably what we call autocross, or AX. In fact I thought it was you folks that called them sloloms. I've run both torque-bias'd (TBD) and clutch-type limited slip differentials (LSD). The TBD is far better for AX events while the LSD diff's likely have a better application on track events like racing, high-speed drivers ed, time-trials and hillclimbs. Both are better than an open differential at getting power to the ground, but drivers new to them have to be careful on wet surfaces until they are familiar with the increased tendency of the car to swap ends in the corners. You'll get a bigger percentage of folks that have those diff's in the Paddock forum on this site. Back on topic: Nice machine work and good to see. |
sixnotfour |
Oct 31 2012, 12:21 PM
Steve, check this thread out ; It is a rare option.
http://www.914world.com/bbs2/index.php?sho...197147&st=0 Hi from across the pond. I would be interested to know how many of you have an LSD fitted? My 1970 1.7 has a factory fitted one, the first owner in the USA did a lot of what we call autotest I think you call them slaloms. I know that in the UK my car is the only 4 cylinder with a factory fitted LSD, and possible the only 914 of any sort with a factory fitted one. Be interested to find out. QUOTE Back on topic: Nice machine work and good to see. Thanks Ron |
914werke |
Oct 31 2012, 04:58 PM
BOT how did you HT? do you have an oven in your garage as well?
sixnotfour |
Oct 31 2012, 05:21 PM
No Oven to 900 at home, Tyee in tooling we have a 2000 degree oven.
Middlefour |
Nov 1 2012, 05:33 AM
sixnotfour |
Nov 3 2012, 12:39 PM
I found a picture of glenn's LSD, Looks like Stoddard did the same thing.
gms |
Nov 12 2012, 09:17 PM
Lo-Fi Version | Time is now: 5th May 2024 - 04:09 AM |
