| kbrunk1 |
Oct 30 2012, 09:15 PM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
OK got the Pelican Valve Adj Made Easy
Got in 5th - driver side wheel in the air -- have rotor at notch. Found Paint on flywheel and notch in housing so I am close to TDC of cyl 1. I can not bend enough to see anything on the flywheel standing from the wheel behind the drivers wheel looking in the hole. Now Pelican says in Figure 11 there is a small opening you can see from under the car near the top of the transmission (? front of the engine bar I assume - found all the tin but no opening. -- you can feel it with your finger ???? (not) Now I assume you pull the covers off with both wheels on? and Pelican says you need to mark the bottom of the flywheel in the gap I can not find. Is this hole on the Oil filer side? Stuck! |
| 914_teener |
Oct 30 2012, 09:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
OK got the Pelican Valve Adj Made Easy Got in 5th - driver side wheel in the air -- have rotor at notch. Found Paint on flywheel and notch in housing so I am close to TDC of cyl 1. I can not bend enough to see anything on the flywheel standing from the wheel behind the drivers wheel looking in the hole. Now Pelican says in Figure 11 there is a small opening you can see from under the car near the top of the transmission (? front of the engine bar I assume - found all the tin but no opening. -- you can feel it with your finger ???? (not) Now I assume you pull the covers off with both wheels on? and Pelican says you need to mark the bottom of the flywheel in the gap I can not find. Is this hole on the Oil filer side? Stuck! Use Capn' Krusty method. Search the site here. |
| Krieger |
Oct 30 2012, 10:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,842 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
The cooling fan is on the front of the motor just behind your right shoulder. There is a black plastic cap on the shroud around it that unscrews so you can look inside at the markings. The flywheel does not have any factory marking, but you could add some. Remove one wheel at a time. I think the pelican proceedure has you using the rear wheel to turn the motor.
| Dave_Darling |
Oct 30 2012, 10:17 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If you're looking at the flywheel, remember that the transmission is at the back of the car. The flywheel is in between the engine and transmission. There is a notch at the bottom of the transmission right where it bolts up to the engine, and another one at the top.
--DD |
| TheCabinetmaker |
Oct 31 2012, 04:42 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Sounds like you have found the notch and paint mark on the fan, not the flywheel. You need the car on jackstands. From under the car, there is a hole in the trans case where it bolts to the engine. You can see the flywheel there. There was a notch on the factory flywheel. There is another hole on the top of the trans case. You can stick your finger in the top hole and feel the notch as you turn the flywheel. When you feel it on the top and the rotor is pointing at the notch in the diz, you are at top dead center of#1. At this point, paint a line on the bottom of the flywheel. Rotate the engine till you see the notch thru the bottom hole and you will be at TDC for the next cylinder . Repeat process till you have done all four .
| balljoint |
Oct 31 2012, 05:03 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Take a couple of big steps back and check to see if your car says FIAT on it anywhere.
| SLITS |
Oct 31 2012, 09:46 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Use Cap'n Krusty's opposite valve method and you won't worry about firing order or notches.
| SLKWrx |
Oct 31 2012, 10:30 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 28-September 04 From: Mickleton, NJ Member No.: 2,845 Region Association: North East States
Use Cap'n Krusty's opposite valve method and you won't worry about firing order or notches. (IMG:style_emoticons/default/agree.gif) I just went through my first adjustment at all and the Pelican method had me scratching my head. Krusty's method was cake, worked like a charm once I got the bailing clamps off (IMG:style_emoticons/default/mad.gif) |
| Spoke |
Oct 31 2012, 10:35 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,351 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Take a couple of big steps back and check to see if your car says FIAT on it anywhere. (IMG:style_emoticons/default/av-943.gif) |
| TheCabinetmaker |
Oct 31 2012, 02:40 PM
Use Cap'n Krusty's opposite valve method and you won't worry about firing order or notches. (IMG:style_emoticons/default/agree.gif) I just went through my first adjustment at all and the Pelican method had me scratching my head. Krusty's method was cake, worked like a charm once I got the bailing clamps off (IMG:style_emoticons/default/mad.gif) I must agree its a better method. I learned it years ago from a local Porsche wrench, and use it myself. However, it might be easier for a first timer, and help him in knowing where these parts of the car are. Never hurts to know how to find tdc, right? |
| tdgray |
Oct 31 2012, 06:25 PM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Better yet....look up a word in the dictionary ....mechanic....find one
| MDG |
Oct 31 2012, 06:30 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Better yet....look up a word in the dictionary ....mechanic....find one well yes . . . there's always that. (IMG:style_emoticons/default/biggrin.gif) |
| scotty b |
Oct 31 2012, 06:32 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Better yet....look up a word in the dictionary ....mechanic....find one How aboot a little compassion here Todduh (IMG:style_emoticons/default/dry.gif) No need to be a |
| Woody |
Oct 31 2012, 06:45 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Hi guys. (IMG:style_emoticons/default/bye1.gif)
| timothy_nd28 |
Oct 31 2012, 06:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
The Cap'n has the superior method. It's actually not that bad, start with the easier set of valves (the most accessible). Make sure you have a stubby spade style screw driver, with a box end wrench (13mm I think). Be sure that your jack stand locks, and you keep your hydraulic jack positioned underneath as a back up. There has been a wrath of jack stand failures recently. It's just peace of mind having a back up, just in case. Best of luck! (IMG:style_emoticons/default/drunk.gif)
| tdgray |
Oct 31 2012, 06:54 PM
Better yet....look up a word in the dictionary ....mechanic....find one How aboot a little compassion here Todduh (IMG:style_emoticons/default/dry.gif) No need to be a My bad....twas a bit dickish |
| Woody |
Oct 31 2012, 06:55 PM
Better yet....look up a word in the dictionary ....mechanic....find one How aboot a little compassion here Todduh (IMG:style_emoticons/default/dry.gif) No need to be a My bad....twas a bit dickish It twer. (IMG:style_emoticons/default/huh.gif) |
| Rand |
Oct 31 2012, 06:59 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Use Cap'n Krusty's opposite valve method and you won't worry about firing order or notches. (IMG:style_emoticons/default/agree.gif) I just went through my first adjustment at all and the Pelican method had me scratching my head. Krusty's method was cake, worked like a charm once I got the bailing clamps off (IMG:style_emoticons/default/mad.gif) I use the new disney star wars method. It's just like krusty's except you leave the valve covers on. No more messing with those evil bailing clamps... or at least it takes less force. |
Lo-Fi Version | Time is now: 12th March 2026 - 09:05 AM |
