Pellican Valve Adjustment Made Easy - Do both valves open at same time? |
kbrunk1 |
Nov 1 2012, 09:57 AM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Unless I missed something, you put it on TDC cyllinder #1 and set exhaust and intake valves.
Just checking but are they both open? Does not seem to make sense to me. |
gothspeed |
Nov 1 2012, 10:03 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Valves should open one at a time unless you have a high overlap camshaft, then they will both be 'partially' open during that overlap period only.
If both your valves are open 'a little' or 'tight' at TDC, then you need to rotate the crank 360° again to get to the compression TDC of that cylinder and adjust the valves at that point. (IMG:style_emoticons/default/smile.gif) |
flash914 |
Nov 1 2012, 10:07 AM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
Tdc #1 combustion both valves would be closed- seated and that is the point that you should be able to feel a little wiggle in the rocker arms. This is the gap you are trying to adjust. Your dist. rotor should also be pointed at the tower for the #1 plug wire.
McMark |
Nov 1 2012, 10:21 AM
I prefer the factory method (one cylinder at a time) simply for its certainty. Nothing wrong with the other methods though.
Woody |
Nov 1 2012, 11:02 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I do em all at the same time. (IMG:style_emoticons/default/huh.gif)
Rand |
Nov 1 2012, 11:05 AM
That's what he was doing. Put it on TDC, and then set exhaust and intake valves. Since they are both open, you can do them all at once. And everyone knows you always adjust valves when they are open. Pay attention. (IMG:style_emoticons/default/poke.gif) |
Cap'n Krusty |
Nov 1 2012, 11:08 AM
Unless I missed something, you put it on TDC cyllinder #1 and set exhaust and intake valves. Just checking but are they both open? Does not seem to make sense to me. They're both closed with that method. Valves are always adjusted closed on most 4 cycle engines. My technique is FAR easier, though ................. The Cap'n |
Rand |
Nov 1 2012, 11:13 AM
Valves are always adjusted closed on most 4 cycle engines. Krunk has a non-most engine. Wait, did Capn say always and most in the same sentence? There you go, just adjust everything so they are all closed. Since closed is binary, you no longer have to worry about the various levels of it. This is genius. I'm sending it to Clymer. |
Woody |
Nov 1 2012, 11:27 AM
That's what he was doing. Put it on TDC, and then set exhaust and intake valves. Since they are both open, you can do them all at once. And everyone knows you always adjust valves when they are open. Pay attention. (IMG:style_emoticons/default/poke.gif) Oh okay. I also do without feelers guages. Just loosen them until they barely wiggle. |
Cap'n Krusty |
Valves are always adjusted closed on most 4 cycle engines. Krunk has a non-most engine. Wait, did Capn say always and most in the same sentence? There you go, just adjust everything so they are all closed. Since closed is binary, you no longer have to worry about the various levels of it. This is genius. I'm sending it to Clymer. I said "most" because solid lifter pushrod Chevys and Audis are adjusted running at full operating temperature. Why would Clymer care about doing things either the best way or the easy way? They're so far behind real life they'll never catch up. They parrot the factory way no matter what. Haynes, too. The Cap'n |
Rand |
Nov 1 2012, 11:29 AM
Why would Clymer care about doing things either the best way or the easy way? They're so far behind real life they'll never catch up. They parrot the factory way no matter what. Haynes, too. The Cap'n Exactly why I think they would buy the Krunk method. Sorry Cap, this has eroded to nonsense. |
Rand |
Nov 1 2012, 11:32 AM
That's what he was doing. Put it on TDC, and then set exhaust and intake valves. Since they are both open, you can do them all at once. And everyone knows you always adjust valves when they are open. Pay attention. (IMG:style_emoticons/default/poke.gif) Oh okay. I also do without feelers guages. Just loosen them until they barely wiggle. Perfect. This is not an exact science. These are NARPs. |
kbrunk1 |
Nov 1 2012, 01:47 PM
That's what he was doing. Put it on TDC, and then set exhaust and intake valves. Since they are both open, you can do them all at once. And everyone knows you always adjust valves when they are open. Pay attention. (IMG:style_emoticons/default/poke.gif) Oh okay. I also do without feelers guages. Just loosen them until they barely wiggle. Perfect. This is not an exact science. These are NARPs. OK Here is the answer.... Turn until Rocking: Adjust: #2 Ex & #3 In #4 Ex & #1 In #1 Ex & #2 In #3 Ex & #4 In #4 Ex & #1 In #2 Ex & #3 In #3 Ex & #4 In #1 Ex & #2 In |
Cevan |
Nov 1 2012, 01:48 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Unless I missed something, you put it on TDC cyllinder #1 and set exhaust and intake valves. Just checking but are they both open? Does not seem to make sense to me. They're both closed with that method. Valves are always adjusted closed on most 4 cycle engines. My technique is FAR easier, though ................. The Cap'n While I agree your method is easy, my method of doing one cyclinder at a time is just as easy and foolproof. Having done this two weekends ago, it took me about 15 seconds to get the engine from TDC of one cyclinder to TDC of the next one. When I first got my car, I put a mark 180 degrees from the TDC mark on my flywheel. Now I just watch for the marks in the window at the bottom of the transaxle. |
tdgray |
Nov 1 2012, 04:13 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
That's what he was doing. Put it on TDC, and then set exhaust and intake valves. Since they are both open, you can do them all at once. And everyone knows you always adjust valves when they are open. Pay attention. (IMG:style_emoticons/default/poke.gif) Oh okay. I also do without feelers guages. Just loosen them until they barely wiggle. Perfect. This is not an exact science. These are NARPs. OK Here is the answer.... Turn until Rocking: Adjust: #2 Ex & #3 In #4 Ex & #1 In #1 Ex & #2 In #3 Ex & #4 In #4 Ex & #1 In #2 Ex & #3 In #3 Ex & #4 In #1 Ex & #2 In Well then why are u asking us (IMG:style_emoticons/default/huh.gif) ....you're on point Start another thread for the next round of responses |
cgnj |
Nov 1 2012, 04:39 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Unless I missed something, you put it on TDC cyllinder #1 and set exhaust and intake valves. Just checking but are they both open? Does not seem to make sense to me. They're both closed with that method. Valves are always adjusted closed on most 4 cycle engines. My technique is FAR easier, though ................. The Cap'n While I agree your method is easy, my method of doing one cyclinder at a time is just as easy and foolproof. Having done this two weekends ago, it took me about 15 seconds to get the engine from TDC of one cyclinder to TDC of the next one. When I first got my car, I put a mark 180 degrees from the TDC mark on my flywheel. Now I just watch for the marks in the window at the bottom of the transaxle. I agree with cevan. I'm a fool I prefer and I prefer "foolproof" . I understand Krusty's method and would use it on close to stock cams. I run a 163/86b. My flywheel is marked. I don't bill for my hours, it's a hobby, so I do it the hard way. Hard way takes less than 2 hours from wheels up to wheels down. Carlos |
Lo-Fi Version | Time is now: 14th May 2024 - 09:40 PM |
