Fiberglass flare installation- Rivet on! |
Trekkor |
Nov 2 2012, 12:42 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Wanting more tire, the time finally came to go wider body.
Here, you can see how easy and fast you can produce a good looking flare install. I started with professionally painted flares and plastic edge molding. Measure and mark the car carefully before cutting: (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1351881777.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1351881777.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1351881778.3.jpg) After holding/clamping the flares in their finished position, trace a light pencil line along the outside edge of the flare onto the car. Apply 2" masking tape to the line. The inside edge of the tape becomes your cut line: (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1351881778.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1351881778.5.jpg) KT |
Jeff Hail |
Nov 29 2012, 06:03 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I think you need to flare that open wheeled chair next. Just doesnt look right with all that rubber hanging out.
Attached image(s) |
The Metal Surgeon |
Nov 30 2012, 01:07 AM
Member Group: Members Posts: 128 Joined: 8-September 12 From: Denver,Colorado Member No.: 14,902 Region Association: None |
I think you need to flare that open wheeled chair next. Just doesnt look right with all that rubber hanging out. or you could do this...... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.themetalsurgeon.com-14902-1354259227.6.jpg) 16hrs start to finish |
Bartlett 914 |
Nov 30 2012, 08:41 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I think you need to flare that open wheeled chair next. Just doesnt look right with all that rubber hanging out. or you could do this...... 16hrs start to finish Looks really good. It would be nice to see more on the welding as you were fitting it in. Is this all weld? Did you need to use filler? |
Lo-Fi Version | Time is now: 11th May 2024 - 02:42 AM |
