oil filter, using a 911 oil filter on a 914? |
tadadavis |
Nov 5 2012, 09:03 AM
Newbie Group: Members Posts: 2 Joined: 1-November 12 From: Lexington KY Member No.: 15,099 Region Association: None |
What are the pros and cons of using a 911 oil filter on the 914?
type47 |
Nov 5 2012, 01:11 PM
I'd venture that it's all con since the 911 filter and 914 are different sizes. Even if you can screw the 911 filter on a 914, the sealing gasket on the 911 filter will miss the sealing surface on the 914 filter tower. If you're thinkin' just because it's a 911 filter it has to be better, that's not necessarily so. Get the proper 914 filter (Mann, Mahle, and I'd like to know about Wix and other brands) and adopt a regular oil change interval....
Cap'n Krusty |
Nov 5 2012, 01:22 PM
The early 911 filter will fit just fine, but it was designed with the high flow rate you get with a dry sump system. Valving may be different, and it's gonna stick about 2" farther down, putting it at risk of getting smacked by anything substantial you might run over.
The Cap'n |
IronHillRestorations |
Nov 5 2012, 03:06 PM
The Cap'n is right, at best all you are gaining is less ground clearance.
Drums66 |
Nov 5 2012, 03:48 PM
.....In a pinch...you can use the 911(filter)but....
just get the right 1.....BTW, it sits paralell with engine bar never ever heard of 1 getting smacked(911 filter,don't be paranoid) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/bye1.gif) |
Elliot Cannon |
Nov 5 2012, 04:02 PM
.....In a pinch...you can use the 911(filter)but.... just get the right 1.....BTW, it sits paralell with engine bar never ever heard of 1 getting smacked(911 filter,don't be paranoid) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/bye1.gif) Pretty sure mine sits perpendicular to the engine bar. Attached image(s) |
Drums66 |
Nov 5 2012, 05:01 PM
.....Meant, flat bottem(horizontal with engine bar) (IMG:style_emoticons/default/idea.gif)
(don't think it is in danger) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) |
Cap'n Krusty |
Nov 5 2012, 06:22 PM
Looking at the photo above, I can see the filter interfering with the cables. Hmm, does the term "saw through the filter" mean anything to you? Once the plastic coating is gone, what you have is a serrated flexible housing rubbing on the thin metal of the filter. All the time.
The Cap'n |
Elliot Cannon |
Nov 5 2012, 06:35 PM
Looking at the photo above, I can see the filter interfering with the cables. Hmm, does the term "saw through the filter" mean anything to you? Once the plastic coating is gone, what you have is a serrated flexible housing rubbing on the thin metal of the filter. All the time. The Cap'n The picture doesn't give you a true perspective since it's 2 dimensional. The cables are at least an inch below the filter. Not even touching. The worn cables came from resting on the bottom of the engine and they don't anymore. The heat of the engine caused the plastic to melt. No danger the cables will "saw through the filter". Does the term "depth perception" mean anything to you? (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/happy11.gif) |
Eric_Shea |
Nov 6 2012, 07:13 PM
scotty b |
Nov 6 2012, 07:18 PM
Elliot Cannon |
Nov 6 2012, 07:21 PM
Oh yeah? Oh yeah? Well, Cap'n Krusty could kick your ass any day. Hah! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/av-943.gif) |
Drums66 |
Nov 7 2012, 02:52 PM
Oh yeah? Oh yeah? Well, Cap'n Krusty could kick your ass any day. Hah! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/av-943.gif) ......Just tell him to use a 911 oil filter, in the 914(will make him feel better!!) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/bye1.gif)(nomore over heating problem's) |
Cap'n Krusty |
Nov 7 2012, 04:33 PM
Looking at the photo above, I can see the filter interfering with the cables. Hmm, does the term "saw through the filter" mean anything to you? Once the plastic coating is gone, what you have is a serrated flexible housing rubbing on the thin metal of the filter. All the time. The Cap'n The picture doesn't give you a true perspective since it's 2 dimensional. The cables are at least an inch below the filter. Not even touching. The worn cables came from resting on the bottom of the engine and they don't anymore. The heat of the engine caused the plastic to melt. No danger the cables will "saw through the filter". Does the term "depth perception" mean anything to you? (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/happy11.gif) Uhhhhhhhhhhhh, Elyut? We're discussing the effects of the added length of a 911 oil filter, NOT the length of the 914 filter in the picture. I can understand your confusion, what with you being from El Paso de Robles and all, but it seems unbelievable that you've lost ALL of your ability to reason and comprehend since you moved up there. Remember, "redneckness has got to be a disease, you catch it on your fingers and it just crawls right up your sleeve". Of course, you came from Orange County, where reason and comprehension are in short supply, so maybe it just wasn't there in the first place .................. Your sympathetic friend, The Cap'n |
MartyYeoman |
Nov 7 2012, 06:01 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Lo-Fi Version | Time is now: 16th May 2024 - 07:13 AM |
