How to hold door window in track ? |
sixaddict |
Nov 5 2012, 04:27 PM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Have a drivers window loose from track. Original was material in the track but cleaned it out.
What do I use to make it reasonably permanent in track. I am sure something is available just not sure. Incidentally trying to avoid pulling it all out of the door. Thanks Terry |
bulitt |
Nov 5 2012, 04:30 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Here's a thread- Window
Mikey914 |
Nov 6 2012, 10:56 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
With the late style window (as shown in the link), I believe you are referring to the "fuzzies" that are helping to hold the window and keep it from banging around.
The good news is the front and rear vertical ones can be replaced with the window in the car. The bad news is the horizontal one on the outside edge of the car will require the window to come out. Usually it's the one that no one has ever replaced as it's more difficult to get to. Hope this helps |
914werke |
Nov 6 2012, 12:36 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Perhaps not Mark.
I just did this with the LE. Late Regulators have a steel guide that secures (with glue) the glass. The bottom edge is wrapped with a rubber sleeve then glued & pressed into that guide. Over 30+ yrs & often window misalignment with the associated pressure on the sliding glass, that glue gives up. You really need to remove the assembly clean it of all the old glue reassemble and reinstall. |
Mikey914 |
Nov 6 2012, 12:40 PM
Let me rephrase it. You can't remove the outer fuzzies without removing the window.
With that being said, if you really want to get it all cleaned up and working properly, you really want to removethe glass as it allows you access to all the seals and it's not that difficult. Say a 3.5 out of 10. Just takes time and patience. |
sixaddict |
Nov 6 2012, 02:06 PM
Thanks ......Even my hands are chlostraphobic so make it a 10
Thanks for the help !! Let me rephrase it. You can't remove the outer fuzzies without removing the window. With that being said, if you really want to get it all cleaned up and working properly, you really want to removethe glass as it allows you access to all the seals and it's not that difficult. Say a 3.5 out of 10. Just takes time and patience. |
76-914 |
Nov 7 2012, 04:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
silicone, and not the cheap crap.
TheCabinetmaker |
Nov 7 2012, 05:01 PM
This topic has been discussed several times. Go to a glass shop or auto paint store and get a tube of urethane.
bulitt |
Nov 8 2012, 12:18 PM
Urethane - (in the link)
FLAPS- 24$ Summit- 17$ Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 10:23 AM |
