1973 2.0 Original Survivor, New brake lines |
914Eric |
Nov 7 2012, 04:07 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Well I'm a newbie, but looking forward to help, comments, and thoughts as I bring my 73 x19 2.0 back to life. It is Phoenix Red, and I am the original owner, well my dad was, but it was always his and my car. I drove the car to my senior prom in 1974.
Dad passed a few years ago, and I finally freed up the time to get started refurbishing it this winter. This is an original California car has been in storage since 1993. I got it out of storage last month after making room in my shop, and am beginning to take it apart. I will post pictures as I go and keep a running blog going so all of you guys (and gals) can keep me from messing anything up. I want to do it right. Thread Index Pages 1-2 Intro photos; 3 Rear tunnel access; 4 seat belts, underbody; 5 fuel tank removal; 6 shocks, sway bars, brakes; 7 engine; 8 engine, ECU; 9 hell hole; 10-11 exhaust; 12-13 originality; 14 wheel align; 15 heater hoses; 16 heat exchangers; engine out; 17 vacuum elbow, fuel pump; 18 wiring; thermostat; 19 cooling flaps, pedal board; 20 pedal cluster; 21 cooling fan; 22 main seals, injector manifolds, rotor; 23 thermostat |
914Eric |
Nov 9 2012, 06:25 PM
OK...I need some help on what I'm looking at in this picture please.
This is a little 4X4 hole with a little sheet metal access cover with one screw holding the cover. It is under the center console near the rear engine wall, between the seat belt connectors. There are 5 things in this access tunnel: A set of wires that can't be seen in the photo A big black tube which I determined was the shift linkage at the very bottom of the access hole and half of it can be seen in the photo some type of hydraulic fitting or connection that is ???? And the 2 red super heavy red duty wires that are ??? They are so heavy duty that they almost feel like steel bars painted the body color? |
Lo-Fi Version | Time is now: 17th May 2024 - 02:39 PM |
