1973 2.0 Original Survivor, New brake lines |
914Eric |
Nov 7 2012, 04:07 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Well I'm a newbie, but looking forward to help, comments, and thoughts as I bring my 73 x19 2.0 back to life. It is Phoenix Red, and I am the original owner, well my dad was, but it was always his and my car. I drove the car to my senior prom in 1974.
Dad passed a few years ago, and I finally freed up the time to get started refurbishing it this winter. This is an original California car has been in storage since 1993. I got it out of storage last month after making room in my shop, and am beginning to take it apart. I will post pictures as I go and keep a running blog going so all of you guys (and gals) can keep me from messing anything up. I want to do it right. Thread Index Pages 1-2 Intro photos; 3 Rear tunnel access; 4 seat belts, underbody; 5 fuel tank removal; 6 shocks, sway bars, brakes; 7 engine; 8 engine, ECU; 9 hell hole; 10-11 exhaust; 12-13 originality; 14 wheel align; 15 heater hoses; 16 heat exchangers; engine out; 17 vacuum elbow, fuel pump; 18 wiring; thermostat; 19 cooling flaps, pedal board; 20 pedal cluster; 21 cooling fan; 22 main seals, injector manifolds, rotor; 23 thermostat |
bigkensteele |
Nov 9 2012, 06:45 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
The two red tubes visible in the photo house the heater cable that open the valves on your heat exchangers. They are controlled by the lever in your console.
If you feel around down under the black shift rod, you will find tubes for your clutch and accelerator cables. If you feel around inside the area that is in the top of the picture, you will find that there are two more plastic tubes. These are your fuel lines, and they MUST be replaced if you want to safely drive the car. After 40 years, they become very brittle. Mine cracked in two when I removed them. If you look in the member vendor forum, you will find them available from Racer Chris and Rotary14. Both are great products at a reasonable price, and actually pretty easy to install. Rotary's thread has a youtube video of the installation. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:29 PM |
