1973 2.0 Original Survivor, New brake lines |
914Eric |
Nov 7 2012, 04:07 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Well I'm a newbie, but looking forward to help, comments, and thoughts as I bring my 73 x19 2.0 back to life. It is Phoenix Red, and I am the original owner, well my dad was, but it was always his and my car. I drove the car to my senior prom in 1974.
Dad passed a few years ago, and I finally freed up the time to get started refurbishing it this winter. This is an original California car has been in storage since 1993. I got it out of storage last month after making room in my shop, and am beginning to take it apart. I will post pictures as I go and keep a running blog going so all of you guys (and gals) can keep me from messing anything up. I want to do it right. Thread Index Pages 1-2 Intro photos; 3 Rear tunnel access; 4 seat belts, underbody; 5 fuel tank removal; 6 shocks, sway bars, brakes; 7 engine; 8 engine, ECU; 9 hell hole; 10-11 exhaust; 12-13 originality; 14 wheel align; 15 heater hoses; 16 heat exchangers; engine out; 17 vacuum elbow, fuel pump; 18 wiring; thermostat; 19 cooling flaps, pedal board; 20 pedal cluster; 21 cooling fan; 22 main seals, injector manifolds, rotor; 23 thermostat |
914Eric |
Nov 10 2012, 05:19 PM
Well...I found my first minor problem. The backpad that is on the engine wall and mounted under the seat wells has 2 of the 4 metal tabs torn away from the cardboard.
Given that it is metal riveted to cardboard...I sure don't see an easy fix. I'm sure there must be a past thread on this topic? |
bigkensteele |
Nov 10 2012, 05:46 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Well...I found my first minor problem. The backpad that is on the engine wall and mounted under the seat wells has 2 of the 4 metal tabs torn away from the cardboard. Given that it is metal riveted to cardboard...I sure don't see an easy fix. I'm sure there must be a past thread on this topic? If you do a search, there is a fantastic thread where a guy restored the cardboard of his backpad using fiberglass. If you read that thread, you will see that it's an easy fix. http://www.914world.com/bbs2/index.php?s=&...st&p=662056 |
Lo-Fi Version | Time is now: 17th May 2024 - 03:31 PM |
