1973 2.0 Original Survivor, New brake lines |
bigkensteele |
Nov 16 2012, 10:53 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Yep, gas pedal mount. Thanks Garold...and nellums. Still haven't got the tank out yet. Dad must of just fueled up last time he drove. Sounds like there is 10-15 gallons of fuel in the tank, and I haven't figured out an easy way to drain it yet. I could do a couple of gallons at a time...But that really sounds messy. (IMG:style_emoticons/default/idea.gif) Go to Home Depot and get 3 of the orange buckets and lids. They are cheap. If you are lucky enough to find an employee who knows the store, ask if they sell a siphon pump and where you might be able to find it. If you don't have any luck, go to Harbor Freight and buy one. It is also cheap. Then you can drain your tank from the top-side in a controlled manner. You will still have 10 - 15 gallons of old gas to get rid of, but at least now it will be in buckets, rather than your tank. After you have done the above, there is still a little gas left in your tank, so you will want to clamp off the lines as close as possible to the nipples on the bottom of the tank. Once they are clamped, just cut them since they will be replaced. Do not have your face directly under the hoses when you cut them unless you like either the taste of old gas or smelling like it for two days. Following the above procedures, you will have a tank ready to be freed, and 2 or 3 buckets of old gas that you will need to get rid of. I used most of mine in my lawn mowers until the carb on my push mower became gummed up. After that, I cut it with new gas for the mowers until it was finally gone. Since you are in California, I would assume that you probably risk arrest for even owning old gas, but there is most likely an EPA office at the end of every street block that can tell you what to do with it. |
914Eric |
Nov 16 2012, 11:12 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
Do not have your face directly under the hoses when you cut them unless you like either the taste of old gas or smelling like it for two days. Since you are in California, I would assume that you probably risk arrest for even owning old gas, but there is most likely an EPA office at the end of every street block that can tell you what to do with it. Ken, In general, your suggestions are pretty good. I didn't like the idea of trying to drain 2 or 3 gallons of fuel at a time out of the bottom. Regarding my face...LMAO...Pretty sure I wouldn't have put my face under it. Do I sound that lame in my posts? (IMG:style_emoticons/default/blink.gif) Also...I don't live in California any more. Moved to Northern Idaho in 2004. Your stereotypes about Cali have a lot more truth than you would think. That's why I moved to Idaho. Thanks... |
bigkensteele |
Nov 16 2012, 11:27 PM
Do not have your face directly under the hoses when you cut them unless you like either the taste of old gas or smelling like it for two days. Since you are in California, I would assume that you probably risk arrest for even owning old gas, but there is most likely an EPA office at the end of every street block that can tell you what to do with it. Ken, In general, your suggestions are pretty good. I didn't like the idea of trying to drain 2 or 3 gallons of fuel at a time out of the bottom. Regarding my face...LMAO...Pretty sure I wouldn't have put my face under it. Do I sound that lame in my posts? (IMG:style_emoticons/default/blink.gif) Also...I don't live in California any more. Moved to Northern Idaho in 2004. Your stereotypes about Cali have a lot more truth than you would think. That's why I moved to Idaho. Thanks... My attempt at humor. A large percentage of the guys here are on the left coast - I was really just throwing them a little softball. With regard to draining the tank, I was stuck in the same place as you about a year ago. It needed to come out, and I had a few gas cans to drain into. I filled them all, and there was still fuel in the tank, so I put a tiny bit in each of our cars. Probably not a good idea, which is why I recommend buying the HD buckets. There are actually many places to dispose of old gas. The siphon pump from HD worked fantastically - much better than trying to drain from below. |
Nov 17 2012, 11:57 AM
914Eric |
Nov 17 2012, 12:40 PM
Looks like the clutch tube came loose at one point, and it was fixed by a U-bolt. That's not the typical spot for it (usually the bolt would be further forward), so it could be some other add-on. --DD This is probably a dumb question, but do you say that becasue there should be no u-bolt threads and nuts hanging down underneath, or because they are in the wrong place? |
Nov 17 2012, 10:25 PM
There wasn't a U-bolt in there originally. The most common reason for a U-bolt in the floor of the center tunnel is a broken clutch tube, which is not uncommon in the 914. But it's not in the typical place for that repair, so it could be something else.
The car looks really nice, BTW! --DD |
914Eric |
Nov 18 2012, 10:17 AM
914Eric |
Nov 19 2012, 12:48 PM
914Eric |
Nov 20 2012, 04:09 PM
sixnotfour |
Nov 20 2012, 04:29 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Wow that things a mess, better go to the east coast and get a real project, for cyrin out loud... (IMG:style_emoticons/default/smile.gif)
914Eric |
Nov 20 2012, 05:28 PM
Madswede |
Nov 20 2012, 06:03 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
Hey Eric, this has been really cool to follow! Great looking car! I see you're in Northern Idaho. My family lives in Boise, and I'm headed up that way for Christmas, driving me and my dog in my truck. Depending on how far north you are and what Highway 55 is looking like, I'm usually in Boise for most of the week between Xmas and New Year's.
As a fellow Phoenix Red 73 2.0 owner (well, OK, it was a 2.0 ... see my sig) I have a small bunch o' FI parts and some other odds n ends that you probably don't need seeing as yours is as good as mine was when I got it in '07. But if there's something you're needing, let me know and I can |
914Eric |
Nov 20 2012, 08:15 PM
As a fellow Phoenix Red 73 2.0 owner (well, OK, it was a 2.0 ... see my sig) I have a small bunch o' FI parts and some other odds n ends that you probably don't need seeing as yours is as good as mine was when I got it in '07. But if there's something you're needing, let me know and I can Thanks Jon, If you have all of the original FI components, I might be interested in the whole set if you would be willing. Having a few spares would be nice. Work me up a price and let me know. |
914Eric |
Nov 21 2012, 01:15 PM
Bottom of the tranny has a nice oil "crust" all along the bottom. The other thing that jumps out at me in the second picture is the duct from the heat exchanger just hanging in the breeze connected with a zip tie.
If you look close, you can also see the aluminum foil wrapped around the fuel lines as a kludge fix to the "won't start when hot" problem. Really Dad?? The u-bolt fix of the clutch is also clear. The good news, is that I'm still not seeing any rust. (IMG:style_emoticons/default/cheer.gif) |
Nov 21 2012, 01:22 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The other thing that jumps out at me in the second picture is the duct from the heat exchanger just hanging in the breeze connected with a zip tie. Actually, someone added that hose to route hot air away from the fuel pump. The heater valve just dumps the hot air under the car when the valve is closed. Someone added a hose to the valve outlet to redirect the hot air away from the pump. Not really a bad idea ... (IMG:style_emoticons/default/idea.gif) |
Nov 21 2012, 01:24 PM
Oh, and the rubber cooling flap on that side is mounted upside-down. The edge needs to point downward for it to work properly.
(IMG:style_emoticons/default/popcorn[1].gif) |
914Eric |
Nov 21 2012, 06:46 PM
Oh, and the rubber cooling flap on that side is mounted upside-down. The edge needs to point downward for it to work properly. (IMG:style_emoticons/default/popcorn[1].gif) You have a VERY good eye Andy. I was wondering about the flaps. One is mounted flush with the underbody and curved down...Which pushes air away from the engine. The other has two inch bolts exposed and hanging down from the underbody with the flap mounted between the bolt head and another nut. This flap is curved up so that the air comes in the two inch gap and is then directed up into the engine. This actually looks like it would work better, but I was pretty sure that it was the one that wasn't the original design. How does the one that pushes air away from the engine actually cool it? Some kind of low pressure drawing it away? |
Pat Garvey |
Nov 21 2012, 07:09 PM
bigkensteele |
Nov 21 2012, 07:40 PM
I was wondering about the flaps. One is mounted flush with the underbody and curved down...Which pushes air away from the engine. The other has two inch bolts exposed and hanging down from the underbody with the flap mounted between the bolt head and another nut. This flap is curved up so that the air comes in the two inch gap and is then directed up into the engine. This actually looks like it would work better, but I was pretty sure that it was the one that wasn't the original design. How does the one that pushes air away from the engine actually cool it? Some kind of low pressure drawing it away? Eric, you are correct - the flaps are designed to create a low-pressure area in the underside of the engine bay. The engine is cooled by pulling air in from the top, pushing it through the tin and out the bottom. I don't think the flaps were on the early cars, but I can't tell you exactly when they were introduced. Looks like someone did a fairly clever modification to yours in the hopes of keeping the fuel pump and lines cool to prevent vapor locks. The fuel pump was moved up front under the gas tank on '75/'76 cars for the same reason. Moving the pump up front is a common and relatively easy modification to earlier cars. It is pretty clear from the extensive tweaks back there that your dad had a problem with vapor locks. I would think about moving the pump up front. |
cwpeden |
Nov 21 2012, 08:49 PM
ok, why cant i see Eric's pics. The curiousity is killin me.
Lo-Fi Version | Time is now: 4th May 2024 - 03:51 AM |
