Another Sti build., Building my 914GTSTI |
914GTSTI |
Nov 8 2012, 05:00 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
914GTSTI |
Jan 27 2015, 10:58 PM
So this is my IDEA list.
Camber & caster weld-in plates? Coilover shocks,F & R. Roll Cage (welded in) Chassis reinforcements. GT Steel fender flairs. Vintage Racing seat ( GT ) Front Welded in swaybar reinforcement. Floor repair (as needed ) Replace jack points. Right Hell Hole wall repair. Firewall to trailing arm mount rod. Cut out air-cooled motor flange. Windshield post reinforcement. (GT ) GT front hood pins and plates. 4 lug to 5 lug swap. Racing tow points F & R . Through hood fuel fill. ( GT Racing ) ? Repair jack points. Bigger brakes F & R ? Cab heater. Cap A/C . Turbo steering Kit. Outside Master battery switch. Some seam welding. 7" and 8" Fluk's. JDM EJ20 T. Megasquirt ECM and harness. Subaru to Kennedy to 901 trans stuff. ColdWater mount. Well its a start. Now I will try to put them into some kind of to do order . Ideas about what to do first ? I'm thinking its the floor,jack points,hello hole ? Kinda work out from their. Randy |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 PM |
