Another Sti build., Building my 914GTSTI |
914GTSTI |
Nov 8 2012, 05:00 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
914GTSTI |
Feb 5 2015, 05:27 PM
I, cleaned up a 914-4 brake rotor and bolted (one hole) to the Boxster hub. It almost self centers. I then tightened up the wheel lug. Used a transfer punch to mark the 5 bolt pattern. Will drill them after getting a bit for a stud mount ? I want to do a mock up so I'm using what I have. Anybody try using allen bolts for wheel studs ? In dirt racing it is a cheep way to go . With some luck the stub's will be here in a day or two ?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1423164673.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1423164673.2.jpg) The trailing arm is in the bead-blaster for cleaning. Then some welding. Any body on the board sell the metal kits for the chassis and trailing arm's ? Randy |
Lo-Fi Version | Time is now: 25th May 2024 - 06:18 PM |
