Another Sti build., Building my 914GTSTI |
914GTSTI |
Nov 8 2012, 05:00 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
914GTSTI |
Feb 19 2015, 07:43 PM
And no, i'm not going to use a 300# spring on the front. And some idiot mounted directional tire on backwards ! What a dip stick.
914forme |
Feb 25 2015, 02:55 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
And no, i'm not going to use a 300# spring on the front. And some idiot mounted directional tire on backwards ! What a dip stick. I was going to ask if you had calculated out the actual spring rate compared to the torsion bars you are replacing. Stock 911 19mm is ~110 Lb/in These are an upgrade to a 914 btw. 21 mm ~ 175 Lb/in 22 mm ~ 210 Lb/in 23 mm ~ 250 Lb/in 24 mm ~ 300 Lb/in 25 mm ~ 350 Lb/in I never calculated the stock 914-4 bar as I never ran them. I rounded the above numbers to match QA1 springs you can buy. You could go variable, as they make 100-200lbs/in and a 140-250lbs/in, and a 175-350lbs/in. Never thought about using them as I have always gone linear. |
Lo-Fi Version | Time is now: 25th May 2024 - 10:07 AM |
