Another Sti build., Building my 914GTSTI |
914GTSTI |
Nov 8 2012, 05:00 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
flmont |
Oct 27 2015, 04:46 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I thought EG33's had the most pwr,..and that the EZ30's were way less pwr,..??? FM
76-914 |
Oct 27 2015, 06:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I thought EG33's had the most pwr,..and that the EZ30's were way less pwr,..??? FM The EG's do have more power and aftermarket parts. They are also longer and heavier. IIRC the EG is 230hp and the EZ is 212hp. The EZ series has a longer engine life, some say. I've no problems using the factory ECU w/ the EZ30D and the car runs quite well. My buddy Chris has been wrestling with his EG33 using a factory ECU. (IMG:style_emoticons/default/confused24.gif) He thinks it could possibly be some engine monitoring devices are hay wire which he will confirm over this winter. So if your on the "EG33 w/ factory ECU bandwagon", stay tuned. Or, forget the factory ECU go MegaSquirt. I think the only thing you would lose is the cold start feature. |
Chris H. |
Oct 27 2015, 07:30 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I thought EG33's had the most pwr,..and that the EZ30's were way less pwr,..??? FM The EG's do have more power and aftermarket parts. They are also longer and heavier. IIRC the EG is 230hp and the EZ is 212hp. The EZ series has a longer engine life, some say. I've no problems using the factory ECU w/ the EZ30D and the car runs quite well. My buddy Chris has been wrestling with his EG33 using a factory ECU. (IMG:style_emoticons/default/confused24.gif) He thinks it could possibly be some engine monitoring devices are hay wire which he will confirm over this winter. So if your on the "EG33 w/ factory ECU bandwagon", stay tuned. Or, forget the factory ECU go MegaSquirt. I think the only thing you would lose is the cold start feature. Megasquirt has the cold start feature. I think my problem is the IAC valve is dirty but I'll check everything when I flip the intake around. Either that or the purge control valve solenoid which is clicking occasionally (and I don't even have the canister hooked up). I also just found out the stock air intake is pretty critical, so I'll switch back to that. The difference between the EZ and the EG is only 20 hp. I've driven both in a 914 and I doubt you could tell which was which if you didn't know. One is definitely NOT way faster than the other in stock form. There is a lot of aftermarket stuff for the EG33, and it is a pretty cool looking engine. It's also very strong and overbuilt internally. That's pretty much it. The EZ is smaller, lighter, newer. And it has a timing chain, not a belt. |
Lo-Fi Version | Time is now: 25th May 2024 - 05:53 AM |
