Another Sti build., Building my 914GTSTI |
914GTSTI |
Nov 8 2012, 05:00 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
914GTSTI |
Feb 4 2015, 12:58 PM
I got a set of Boxster hubs. Now I need to know if a 1976 911, 108mm stub will work with it. I have read a little about needing a spacer,and I can make that. And the need to add mounting holes to tie it to the hub.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1423076323.1.jpg) Thinking about staying with a parking brake. Was thinking after reading, that a 914-6 brake rotor and a spacer on the 914 caliper would be the way to go ? Do I have that right ? With it being a 930 flange it looks to be a little tight but should work. Think I will use a small offroad CV boot ? Because of the Subaru trans I will build the a flange for another 930 and use 28 spline offroad axles. What do you think ? Thanks,Randy |
Lo-Fi Version | Time is now: 5th May 2024 - 01:16 PM |
