| 914GTSTI |
Nov 20 2012, 05:00 PM
Member ![]() ![]() Group: Members Posts: 275 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
So I got the motor a trans out of storage. I am think of going air to water to air for the innercooler. I have one of a JDM,its in the photo. Think it is on a 220 HP motor.????
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353452436.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353452436.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353452436.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353452436.4.jpg) The exhaust was built,maybe 5 years ago. My bad! (IMG:style_emoticons/default/sad.gif) But I'm back at now! |
| 904svo |
Nov 20 2012, 05:19 PM
904SVO ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
When I put a Subaru 2007 wrx engine in my kit car I ran into the same problem.
I installed a 7" fan which pulls the air through the cooler and exhaust the air to the transmission area, the fan is control by the VSS sensor, when it pulses it turns on the fan. Here are some pictures of it. ![]() ![]() |
| 914GTSTI |
Nov 20 2012, 10:45 PM
Thanks 904! Think I will stay with water.
Up front I have lots of room for a heat exchanger for the intercooler. Been working out the Rad. for the motor and will just ad a Rad. for the exchanger. Thinking a 24" by 12" by 1" would do the job? (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353473102.1.jpg) |
| 914GTSTI |
Nov 20 2012, 10:54 PM
Some one was asking,some time back what the FWD trans looked like. Here is a photo of the 914 and the FWD Subaru tran's. Is that a word? LOL
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353473647.1.jpg) |
| 914GTSTI |
Nov 24 2012, 04:46 PM
Here is a link to the chassis cleaning/Soda blasting.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353797217.1.jpg) http://www.914world.com/bbs2/index.php?showtopic=198596 |
| badmiata |
Nov 24 2012, 06:43 PM
Newbie ![]() Group: Members Posts: 47 Joined: 21-June 07 From: Houston, TX (Clear Lake) Member No.: 7,826 Region Association: None |
Cant wait to see your progress. Ive been in DBCoopers car and it was awesome. He is using both the engine and a wrx trans converted to fwd. I think thats the best. He also went with air to water. I have been considering doing the same. How will you vent for the radiator?
| 3d914 |
Nov 24 2012, 07:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Randy, (IMG:style_emoticons/default/welcome.png)
Looks like a nice setup. Have you checked the the dimensions on 914 body? You might want to check that they're close before investing lotta time in the body work. I have the paper copies showing where to measure and proper dimensions - could scan them to PDF and send you. I'm sure someone has posted them on this site though. Keep the pics coming. |
| 914GTSTI |
Nov 24 2012, 07:55 PM
Randy, (IMG:style_emoticons/default/welcome.png) Looks like a nice setup. Have you checked the the dimensions on 914 body? You might want to check that they're close before investing lotta time in the body work. I have the paper copies showing where to measure and proper dimensions - could scan them to PDF and send you. I'm sure someone has posted them on this site though. Keep the pics coming. You must be kidding? With all the welding I have see on this site,what's a little twist? LOL (IMG:style_emoticons/default/cheer.gif) And if it needs it will just put it on the frame machine and pull the Sh&% out of it. (IMG:style_emoticons/default/blink.gif) Thanks for the offer on the scan! Think I'm good. Don't know about the venting? Was thinking about something like this. (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1353808504.1.jpg) |
| 914GTSTI |
Jan 26 2015, 02:11 PM
I am moving back over here with rust repair of my project.
As you can see I'm back at it. Photos are the only 2 areas on the floor that will nee work. I'm thinking a small welded in panel ? Ideas from what you guys have done ? (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422303083.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422303083.2.jpg) |
| 914GTSTI |
Jan 26 2015, 03:12 PM
| 914GTSTI |
Jan 26 2015, 06:10 PM
A Little more cleaning.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422317415.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422317415.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422317415.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422317416.4.jpg) Looks like I will have some work to do in the Hell Hole ! But not as bad as most have had to deal with. (IMG:style_emoticons/default/piratenanner.gif) |
| 914GTSTI |
Jan 26 2015, 06:12 PM
With me building a water cooled 914 should I pull the air skirt mounts ?
| Mike Bellis |
Jan 26 2015, 08:01 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Depends on how far you're willing to go... (IMG:style_emoticons/default/evilgrin.gif)
I removed most of the engine shelf and made other modifications. There's no going back now but I was not the first one to cut into the car. (IMG:style_emoticons/default/sawzall-smiley.gif) |
| 914GTSTI |
Jan 26 2015, 08:04 PM
And what about the battery tray ? Not sure their is a better place for it but I figured I would ask.
| Mike Bellis |
Jan 26 2015, 08:15 PM
| 914GTSTI |
Jan 26 2015, 09:30 PM
What about the balance of the car ? With moving the battery that far forward is their a down side ?
| mgp4591 |
Jan 26 2015, 09:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
You're taking weight away from a higher center of gravity point in the rear to a very low COG point just over the front axle. The new engine weighs more so in theory you should be better sorted this way. Should help even out the whole weight distribution thing and still keep the weight close to the center of the car which helps your handling. Would be interesting to see some others battery boxes and ideas tho... (IMG:style_emoticons/default/idea.gif)
Has anyone gone with a gel-cel inside the passenger compartment? Is it even recommended? (IMG:style_emoticons/default/confused24.gif) |
| 76-914 |
Jan 26 2015, 11:09 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,965 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
You've already added fans, water and a radiator to the front so I'd keep that batt in the engine compartment. Scales will say it all.
| 914GTSTI |
Jan 26 2015, 11:57 PM
I will need to find out what the Subaru starter needs in the way of a battery. Maybe I could push it more down into the "hell hole" ?
| mgp4591 |
Jan 27 2015, 01:11 AM
You've already added fans, water and a radiator to the front so I'd keep that batt in the engine compartment. Scales will say it all. But all that is AHEAD of the front axle- keeping or adding weight on top or just behind the front axle could help the balance... (IMG:style_emoticons/default/idea.gif) Anyone ever measured the weight of a Suby conversion at all 4 corners? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 21st September 2026 - 09:00 AM |
