Another clutch tube on the LOOSE, (EDIT) Not a clutch tube problem..... H E L P |
jsayre914 |
Nov 9 2012, 10:41 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Got off work last night and car started right up, its running awesome. Pulled to the traffic light, sitting in neutral. Light turns green, I reach for the clutch, its not where it was (IMG:style_emoticons/default/sad.gif) Its half way down to the floor, no gears at all. I roll to the side and adjust the nut all the way in on the tranny adjustment, pedal comes back up, till I push on it.... I get my buddy to pull behind me and give me a push to engage 2nd and I make it through 3 lights speed shifting till I get to 83. Then it was smooth sailing, speed shifting is easy (stopping is hard (IMG:style_emoticons/default/rolleyes.gif) ) When I got to the end of the highway, I kept it in 2nd and timed each light (chugging to the red ones.
I made it (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Now where are all those threads on clutch tube repair ?? (IMG:style_emoticons/default/dry.gif) Joseph |
VaccaRabite |
Nov 9 2012, 02:38 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If only you had a bud with a welder.
jsayre914 |
Nov 9 2012, 05:11 PM
If only you had a bud with a welder. I still need to investigate. I am working all the time, and then I am home trying to finish the new bathroom. Car time does not exist at this time (IMG:style_emoticons/default/sad.gif) I think my next step would be to remove the console, carpet, shifter. Then see if the tube is in fact loose. I have a good view from the back, the tube is solid there with no cracking. I also saw the pivot arm is in the same position that its always been. So prolly not a tranny problem. If I only had more hours in a day........................................................................................................................................................... (IMG:style_emoticons/default/golfer.gif) |
type47 |
Nov 9 2012, 05:33 PM
You might be able to temporarily bolt the tube to the tunnel to squeeze out a couple more miles until Zach warms up his welder (IMG:style_emoticons/default/welder.gif)
ChrisFoley |
Nov 10 2012, 08:24 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If its not the clutch tube or the clutch cable, check to see if you've sheared the roll pin at the pedal where it attaches to the shaft in the pedal cluster.
scotty b |
Nov 10 2012, 08:45 AM
The fact that you tightened the nut down, got pedal back and then it went away once you pushed it bothers me. Check the pin like Chris mentioned, and if that is fine then look at the throwout arm as well. I've seen a couple of them actually crack in two. Usually at the fingers on one end or the others, but I have seen one break near the center of the arm. I always assumed that one had been in an accident and no-one noticed it was bent until it broke (IMG:style_emoticons/default/confused24.gif)
scotty b |
Nov 10 2012, 08:47 AM
Oh and the firewall....definitely look at the firewall where the tube comes through. That would also explain why you got pedal back then lost it under pressure again
scotty b |
Nov 11 2012, 06:29 PM
jsayre914 |
Nov 11 2012, 06:48 PM
Car is sitting under the umbrella cover, I have had NO time to look. I am building another bathroom in my closet. Driving the Suby (IMG:style_emoticons/default/sad.gif) I will get to it (IMG:style_emoticons/default/popcorn[1].gif) |
scotty b |
Nov 11 2012, 07:10 PM
I am building another bathroom in my closet. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/stromberg.gif) 5 gallon bucket ? (IMG:style_emoticons/default/unsure.gif) |
jsayre914 |
Nov 12 2012, 04:16 PM
(IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/stromberg.gif) 5 gallon bucket ? (IMG:style_emoticons/default/unsure.gif) See for yourself http://www.914world.com/bbs2/index.php?sho...=197984&hl= |
jsayre914 |
Nov 14 2012, 11:13 AM
Had an hour to take a look.
Pulled the rear acess panel in the center and tube is perfect, no wiggle. Looked under the gearshifter, tube was strong and weld was perfect. Not a Clutch tube problem. Pedal cluster was perfect, rebuilt recently and the small piece with the pin was fine. Now onto the tranny. I put the cable back on till it was tight like it should be, it took about 20 washers (IMG:style_emoticons/default/blink.gif) and the fork was angled slightly tward the rear of the car. I know thats not right. I removed the cable and noticed that there is about an inch of slop on the fork. It has too much play. it now sits in the middle of the hole and I can wiggle it foreward and backward. What happened???? (IMG:style_emoticons/default/WTF.gif) Oh yeah, its a new clutch with less than 10k miles |
Jeffs9146 |
Nov 14 2012, 11:27 AM
A couple of things could have happend but I would guess that one of the spacers that goes between the TO Bearing and the Y Fork broke or the plastic spacer in the ball cup in the Y Fork broke!
ws91420 |
Nov 14 2012, 11:32 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Cable could be breaking a few strands at a time and stretching.
euro911 |
Nov 14 2012, 11:57 AM
My wife's clutch started needing adjustment weekly ... then daily. When we puled the drive train - turned out to be the cable (stretching).
If you pull the drive train and it turns out to be your throw our arm bushing, replace it with a bronze one 'while you're in there' (IMG:style_emoticons/default/idea.gif) Nice bathroom addition too (IMG:style_emoticons/default/thumb3d.gif) |
Rockaria |
Nov 14 2012, 12:15 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
...I removed the cable and noticed that there is about an inch of slop on the fork. It has too much play. it now sits in the middle of the hole and I can wiggle it foreward and backward.... My bet is that either the bushing (Plastic Ball Cup) under the fork or the small clip holding the clutch fork got loose and the fork is now just dangling. Can you pull down on the fork and does it come loose from the throwout bearing? my 27 centavos, |
Cap'n Krusty |
Nov 14 2012, 12:43 PM
My wife's clutch started needing adjustment weekly ... then daily. When we puled the drive train - turned out to be the cable (stretching). If you pull the drive train and it turns out to be your throw our arm bushing, replace it with a bronze one 'while you're in there' (IMG:style_emoticons/default/idea.gif) Nice bathroom addition too (IMG:style_emoticons/default/thumb3d.gif) "Bronze one"? The Cap'n |
euro911 |
Nov 14 2012, 01:14 PM
With the exception of the firewall bushing (replaced that with a CFR spherical), we replaced all the plastic bushings with bronze ones. Maybe THOMAS made the ones I have? (IMG:style_emoticons/default/confused24.gif)
VaccaRabite |
Nov 14 2012, 08:37 PM
The good news is that pulling the trans is not nearly as involved as pulling the whole engine.
Sounds like you will need to do that. |
Dr Evil |
Nov 15 2012, 10:47 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Not the cable. If the arm has that much slop, then it is a pivot/retainer and bolt/ arm/bushing issue. The cable may be contributing, but it is not the primary cause.
Lo-Fi Version | Time is now: 21st May 2024 - 06:12 PM |
