New Toyo Proxes RR, know anything about them? |
PlaysWithCars |
Nov 14 2012, 12:52 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Anyone know anything about them? Looks like a new tire that will be spec tire for Miata and 944 series which means they come in 914 sizes. (IMG:style_emoticons/default/piratenanner.gif)
They are a track tire, but wonder how they will do for autocrossing. Similar to the Kuhmo V710 but not as good as Hoosier A6? |
Trekkor |
Nov 14 2012, 10:13 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I should have a good amount of data on this before long.
Until then, realize they are still treadwear 100. 710's are a great a/x tire. KT |
stuttgart46 |
Nov 14 2012, 10:16 AM
Member Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
I'm hearing good things so far as a track tire. Hopefully I'll be trying these out very soon.
helios |
Nov 14 2012, 04:33 PM
Member Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest |
I would highly doubt they are even up to the V710s performance.....just based off the fact they are designed for different environments.
Autocross tires can run a much more aggressive rubber compound, as the heat cycle durations are much shorter. Road Race tires have to be able to run for dozens of laps at pace (not counting super sticky qually tires), as such, the rubber compounds can't be as aggressive, to prevent overheating that leads to blistering/delaminating and ultimately tire failure. If you are looking for a dual role tire (or an autox tire with a longer life, at the expense of grip)...could be worth looking into. But if you are strictly looking for an autocross tire...I would stick w/ the autocross specific tires (V710/A6 and such). |
PlaysWithCars |
Nov 14 2012, 11:29 PM
I've been using the V710s for a couple of years and really like them. Don't think they're quite as sticky as the A6, but they hold up well and are cheaper than A6s. Just saw the RRs and thought maybe they would be competitive with the V710s and are cheaper yet.
Clearly a track and not an autocross tire, but so is the V710 yet it does pretty good on the autocross course. How about the Hankook Ventus Z214 in the C71 soft compound. Also a bargain compared to the Hoosiers or Kuhmos, but gets pretty good reviews on TireRack |
PlaysWithCars |
Nov 25 2012, 01:23 AM
Info on the Toyo RRs is on it's way. My buddy runs a tire shop that has exclusive rights to Toyo in their region. He checked with corporate and they hadn't heard of them yet because they are so new. They're going to Toyo to get the scoop on them.
Lo-Fi Version | Time is now: 15th May 2024 - 07:27 PM |
