| JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
| TravisNeff |
Nov 14 2012, 01:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
You just need the bearing, its a sealed unit so the bearing and races are all one part
| Jeffs9146 |
Nov 14 2012, 01:14 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Just the bearing! (IMG:style_emoticons/default/beerchug.gif)
You might as well replace the bushings also while your in there!! |
| Tom_T |
Nov 14 2012, 02:24 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Just the bearing! (IMG:style_emoticons/default/beerchug.gif) You might as well replace the bushings also while your in there!! (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/laugh.gif) .... and that's where it starts! "while I'm in there...." |
| SLITS |
Nov 14 2012, 03:01 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
CV has to be removed, along with caliper and rotor.
Hub will have to be removed first or after bearing and hub are pounded out. You need a tool to reinstall the bearing and hub. Without the proper support the bearing will be destroyed upon hub reinstall. |
| matthepcat |
Nov 14 2012, 03:24 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
You will also need a freezer and time to let it freeze for two days, or dry ice. You might also want a torch.
| JawjaPorsche |
Nov 14 2012, 04:25 PM
I read about the freezer trick earlier and was planning to do. Getting bearing tomorrow and will freeze until Monday! (IMG:style_emoticons/default/beerchug.gif)
You will also need a freezer and time to let it freeze for two days, or dry ice. You might also want a torch. |
| Jeffs9146 |
Nov 14 2012, 04:36 PM
If your mechanic is doing the work then he will need to freeze it because it needs to come out of the freezer and directly into the trailing arm before it warms and expands!
I leave a 60w light on the trailing arm for a few hours before and coat it with a light coat of grease. Then I put the frozen bearing in and most of the time it slides in like butter!! But if you wait to long it will stick and you have to finish by pressing it the rest of the way in! PS: It is way easier to do it on the bench than on the car! |
| Van914 |
Nov 14 2012, 04:38 PM
Van914 ![]() ![]() ![]() Group: Members Posts: 702 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest
Made my own tool using pipe and caps from the Home Depot. Get pipe to contact the outside of the bearng.
Also used a BFH (IMG:style_emoticons/default/smash.gif) Then I used an extra stub axle to finish. Just one way Van914 |
| JawjaPorsche |
Nov 14 2012, 04:44 PM
I was going to pack it in ice before taking to the mechanic on Monday. He has a freezer and we will put in there while we dissemble the hub, CV axle, old bearing, etc! We will try to get heat on the trailing arm. It is going to low 30's Monday morning.
Thanks for the tip! (IMG:style_emoticons/default/beerchug.gif) If your mechanic is doing the work then he will need to freeze it because it needs to come out of the freezer and directly into the trailing arm before it warms and expands! I leave a 60w light on the trailing arm for a few hours before and coat it with a light coat of grease. Then I put the frozen bearing in and most of the time it slides in like butter!! But if you wait to long it will stick and you have to finish by pressing it the rest of the way in! PS: It is way easier to do it on the bench than on the car! |
| 914itis |
Nov 14 2012, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Made my own tool using pipe and caps from the Home Depot. Get pipe to contact the outside of the bearng. Also used a BFH (IMG:style_emoticons/default/smash.gif) Then I used an extra stub axle to finish. Just one way Van914 (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
| bandjoey |
Nov 14 2012, 05:01 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
PBM videos on U tube of tear down and install
| SLITS |
Nov 14 2012, 06:25 PM
| Jeffs9146 |
Nov 14 2012, 06:28 PM
| 76-914 |
Nov 14 2012, 08:50 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,869 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I've done them in the car but next time I'm pulling the arm so I have an excuse to buy a press. (IMG:style_emoticons/default/biggrin.gif)
| somd914 |
Nov 14 2012, 09:57 PM
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I had no luck getting a bearing out recently - tried various versions of the homemade bearing pullers, tried a BFH, tried even a bigger BFH, still no joy, cried uncle and took the trailing arm to the shop and let them press it out.
If you are installing the hub vice your mechanic, don't forget to install the bearing cap (retainer) before installing the hub - failure to do so will result in stream of profanity and likely a ruined bearing. (IMG:style_emoticons/default/headbang.gif) |
| cwpeden |
Nov 15 2012, 12:23 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
CV gaskets?
| Amphicar770 |
Feb 9 2016, 08:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,226 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
I know this is an old thread but I saw something even older on another forum that I thought might be useful. I cant take credit, the author was someone named SammyG
bearings and any other parts that are designed to have an interference fit need to be installed in one of two ways, either with a press pushing on the correct place (either inside or outside race depending on where the interference is) or you need to temporarily eliminate the interference fit with temperature diferentiation. heat the outer part and/or cool the inside part and you suddenly have clearance until the temperatures normalize. What you should have done was to put the hub in the freezer and put the bearings in the oven and heat them up to around 230 degrees F. Then carefully slide the bearings onto the hub. Then put the entire hub with bearings in the freezer (inside a plastic bag) until it is cold then carefully insert it into the control arm. No hammers allowed. |
| rjames |
Feb 10 2016, 12:09 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,439 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
The correct schnorr washers for the cv bolts for when you put them back in.
| veekry9 |
Feb 10 2016, 12:46 AM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
.......No hammers allowed. ^ Agreed, If a proper press or extractor is not available,a hammer is the way to damage the bearing. Cooking the bearings in clean oil to above 212 F,more like 300 F,will allow the bearing to slip onto a chilled shaft. Both must be checked for actual dimensions and the resulting interference at operational temperature.SOP. Roller bearing crankshafts and spindles have certain required methods. Induction heating of bearings or housings is another way,production oriented. https://www.google.ca/webhp?sourceid=chrome...=bearings%20101 https://www.google.ca/webhp?sourceid=chrome...%20installation https://www.google.ca/search?q=bearing+pull...anSDP0Q_AUIBigB In the machine trade,smoking a 30K$ machine bearing is not an option,therefore expertise and experience is applied. / |
Lo-Fi Version | Time is now: 12th March 2026 - 02:03 PM |
