Final Batch of parts, Mostly 914, but some 911 stuff |
avidfanjpl |
Nov 14 2012, 10:59 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Ho Ho Ho!
This is the last batch of parts for sale. I ship from Paypal payments and need complete addresses to complete shipping. PM me for my PP email address. Thanks! John Front Brake dust shield - $10 Working AAV's - $25 each - Guaranteed to work 914 2.0L 73/74 ECU - $200 2, 4 and 6MM shims - $75 for the set NIB Gauge plate - $25 with 2 medium rubber gaskets Aluminum lid rollers - $20 Redone light buckets - $50 for the set 3 Working OEM relays - Very clean $25 Crisp Rear trunk working light - $25 2.0L FI Gaskets $18 for both NIB 3 - NIB 2.0L Exhaust gaskets $8 for 3 in bags 2 - 2.0L exhaust copper gaskets - $3 for both 2.0L Rearview - Good shape - $25 Good quality flasher switch - $25 Nice 914 Speedo Assy - New O ring - $55 Nice and rare 911 Speedo Assy - New O Ring - Does not work with 914 speedo - Rare Brass body - $95 911 Rear lenses - $40 - one has a slight crack 911 Dizzy Cap - 3.2L - $30 914 2.0L Repop Fuch Acorn bolts - Good shape - 17 pieces - $68 Unused Mahle 2.0L air filter - $10 Clipped off ECU connector - $20 009 HTS - $25 Mahle Euro NIB 2.0L 8 to 1 compression Piston set with jugs, pistons, wrist pins and wrist pin snap rings - $914 1973 914 2.0L Split case with new case Bolts set - needs .020 line boring - GA0009772 - $300 914 2.0L Crankshaft and drive gears - $150 - Machined mains .010, rod journals are spec 914 20L Camshaft - $50 Yes, there are some items in there that someone may want that I didn't type out, see if you can find them and pay for shipping and they are yours. Interesting little things in the main pic. THANKS!! John |
0396 |
Nov 15 2012, 12:50 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
2, 4 and 6MM shims - $75 for the set NIB... what are these used for?
avidfanjpl |
Nov 15 2012, 01:46 AM
Shimming the trailing arms to correct sagging in the rear of the car, but good shocks and springs typically correct it. Economy in a shim till one can change out about $300 in parts needed.
Sometimes even with shocks and springs, there is a bit of shim needed. Anyone want to add better comments? John |
0396 |
Nov 15 2012, 04:40 AM
Shimming trailing arm. Oh that what I thought you meant to say. I was inquiring of the packet of copper rings. What are those used for? Oh I think it's an o-ring in that plastic bag.
I could use new case bolts and the studs that hold the P/C s. Are those new and if so, how much? Thanks |
pilothyer |
Nov 15 2012, 06:53 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Hi John...........Please let me know the shipping on the following:
NIB Battery Clamp - $6, NIB Clutch Accordian Boot - $5, Rubber and steel CV boot and flange - $10 NIB, 3 Port working fuel pump $55. Thanks in advance...............Jerry |
avidfanjpl |
Nov 15 2012, 10:59 AM
PM'd you, Jerry!
Thanks, J Hi John...........Please let me know the shipping on the following: NIB Battery Clamp - $6, NIB Clutch Accordian Boot - $5, Rubber and steel CV boot and flange - $10 NIB, 3 Port working fuel pump $55. Thanks in advance...............Jerry |
avidfanjpl |
Nov 15 2012, 11:03 AM
Hey 0396,
Those copper rings are for a 2 liter exhaust manifold. Not a 1.7 or 1.8. You need 2 more to do all 4 pipes. The case bolts are already sunk into the motor halves. I can't remove them. I am not sure who makes them, as they were already in the short block when I bought it. Maybe Jonathan at GPR knows? Thanks, John Shimming trailing arm. Oh that what I thought you meant to say. I was inquiring of the packet of copper rings. What are those used for? Oh I think it's an o-ring in that plastic bag. I could use new case bolts and the studs that hold the P/C s. Are those new and if so, how much? Thanks |
carsten |
Nov 16 2012, 11:13 AM
I'm new here ... Group: Members Posts: 0 Joined: 2-September 12 From: Leipzig Member No.: 14,885 Region Association: None |
I would take the NOS 914 radio faceplate and the black 911 aluminum nuts.
Do you know how much shipping is to 29681? Thanks Carsten |
silver74insocal |
Nov 16 2012, 04:43 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
"Yes, there are some items in there that someone may want that I didn't type out, see if you can find them and pay for shipping and they are yours. Interesting little things in the main pic."
cv boots, is that a clutch cable boot? and a 3 port fuel pump do i win them? haha i am also interested in your fuch lug bolt repops.. let me know thanks, Dave |
avidfanjpl |
Nov 16 2012, 08:42 PM
Hey Dave!
PP sent. Thanks! John "Yes, there are some items in there that someone may want that I didn't type out, see if you can find them and pay for shipping and they are yours. Interesting little things in the main pic." cv boots, is that a clutch cable boot? and a 3 port fuel pump do i win them? haha i am also interested in your fuch lug bolt repops.. let me know thanks, Dave |
avidfanjpl |
Nov 16 2012, 08:46 PM
Hello Teeners,
If it doesn't ship by Monday, really latest Tuesday, as my dad Robert A Lewis, Sr said over Hiroshima, "There will be a pause while we bomb our target." My Mom, his widow, had a stroke and I will be out of town until 12/2. Thanks to all, and you have 3 days to pick and pay. I send the last box out Tuesday after my freaking root canal. Thanks! John |
avidfanjpl |
Nov 20 2012, 09:12 PM
Shameless bump!
J |
bozo914 |
Nov 21 2012, 10:59 AM
Slacker Group: Members Posts: 284 Joined: 27-October 10 From: Richmond VA Member No.: 12,325 Region Association: MidAtlantic Region |
I'll take the Aluminum lid rollers - $20. PayPal OK?
Lo-Fi Version | Time is now: 18th May 2024 - 01:33 PM |
