Ho Ho Ho!
This is the last batch of parts for sale.
I ship from Paypal payments and need complete addresses to complete shipping.
PM me for my PP email address.
Thanks!
John
Front Brake dust shield - $10
Working AAV's - $25 each - Guaranteed to work
914 2.0L 73/74 ECU - $200
2, 4 and 6MM shims - $75 for the set NIB
Gauge plate - $25 with 2 medium rubber gaskets
Aluminum lid rollers - $20
Redone light buckets - $50 for the set
3 Working OEM relays - Very clean $25
Crisp Rear trunk working light - $25
2.0L FI Gaskets $18 for both NIB
3 - NIB 2.0L Exhaust gaskets $8 for 3 in bags
2 - 2.0L exhaust copper gaskets - $3 for both
2.0L Rearview - Good shape - $25
Good quality flasher switch - $25
Nice 914 Speedo Assy - New O ring - $55
Nice and rare 911 Speedo Assy - New O Ring - Does not work with 914 speedo - Rare Brass body - $95
911 Rear lenses - $40 - one has a slight crack
911 Dizzy Cap - 3.2L - $30
914 2.0L Repop Fuch Acorn bolts - Good shape - 17 pieces - $68
Unused Mahle 2.0L air filter - $10
Clipped off ECU connector - $20
009 HTS - $25
Mahle Euro NIB 2.0L 8 to 1 compression Piston set with jugs, pistons, wrist pins and wrist pin snap rings - $914
1973 914 2.0L Split case with new case Bolts set - needs .020 line boring - GA0009772 - $300
914 2.0L Crankshaft and drive gears - $150 - Machined mains .010, rod journals are spec
914 20L Camshaft - $50
Yes, there are some items in there that someone may want that I didn't type out, see if you can find them and pay for shipping and they are yours. Interesting little things in the main pic.
THANKS!!
John
