Nozzle |
Member ![]() ![]() Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region ![]() |
I need to replace the two lower fuel tank outlet and inlet gaskets and I've read that Viton seems to work best for today's fuels. When I run searches for Viton gaskets, all I seem to find is bulk suppliers that want to know how many hundred I need.
Does anyone have a source for these gaskets that sell single gaskets for this application? Thanks, John |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I have some strainer gaskets.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
helios |
Member ![]() ![]() Group: Members Posts: 234 Joined: 15-May 08 From: Bellingham Wa Member No.: 9,055 Region Association: Pacific Northwest ![]() |
We've ordered custom viton gaskets at the refinery I work at through the Bellingham Lamons facility. You can try contacting the nearest branch. Whether or not they sell to the private sector...I do not know.
Lamons locations |
Nozzle |
Thanks for the link Jeff. That's the first site I've seen that will sell individual gaskets. Looks like the smallest size they sell is too big for the fuel tank applications which are 8mm ID for the return and 10mm ID for the supply fittings. Sounds like I may have to go with the standard copper washers from AA if they don't make the Viton in smaller sizes. |
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
viton cuts easily - I made my own fuel tank gaskets from a small sheet of viton I procured from an engineer at work.
LotusJoe |
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California ![]() |
You can buy a bulk sheet.
http://www.mcmaster.com/#standard-viton-fl...gaskets/=k8z0xm Oops, I just saw the price (IMG:style_emoticons/default/confused24.gif) a bit much for just making a couple gaskets. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I can do this. And in some quantity these can be cost effective.
-Mark |
Mikey914 |
Thanks for the link Jeff. That's the first site I've seen that will sell individual gaskets. Looks like the smallest size they sell is too big for the fuel tank applications which are 8mm ID for the return and 10mm ID for the supply fittings. Sounds like I may have to go with the standard copper washers from AA if they don't make the Viton in smaller sizes. What thickness? 1/8"? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
"Standard copper gaskets"? IIRC, they're fiber, not copper. Viton would crush, squeezing out and the connection would likely have a tendency to loosen over time. It needs a defined space to function properly.
The Cap'n |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Yes on the fiber washer. They are available at the bughaus.com for a few bucks each and work great. Just like the stock. Eric is a good guy and carries a lot of type 4 stuff.
TheCabinetmaker |
Oh yeah, he carries the strainer sock too.
Nozzle |
Thanks for the replies folks. Does anyone know if the fiber parts have problems with current fuel blends? I thought that was the idea behind the new Viton parts.
Cap'n Krusty |
Fiber don' care ........................
The Cap'n |
Mikey914 |
I had head that the OEM material was not as tollerent to ethanol. I'm doing some reasearch to see if they can be made inexpensively out of a more modern material, and at what cost. But only if the OEM ones are a problem. But from what I have heard here that may not be necessary.
Mikey914 |
I have aquired 3 diferent grades of Viton and I'm conducting some testing to see how the material perform. Standard gas and E85. I'm interested as to how these will perform.
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,917 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
I've just been VERY careful when dealing with the original ones. Interested in the outcome ... (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 30th July 2025 - 04:09 PM |
