Nozzle
Nov 20 2012, 10:52 AM
I need to replace the two lower fuel tank outlet and inlet gaskets and I've read that Viton seems to work best for today's fuels. When I run searches for Viton gaskets, all I seem to find is bulk suppliers that want to know how many hundred I need.
Does anyone have a source for these gaskets that sell single gaskets for this application?
Thanks,
John
ChrisFoley
Nov 20 2012, 11:16 AM
I have some strainer gaskets.
underthetire
Nov 20 2012, 11:58 AM
helios
Nov 20 2012, 12:14 PM
We've ordered custom viton gaskets at the refinery I work at through the Bellingham Lamons facility. You can try contacting the nearest branch. Whether or not they sell to the private sector...I do not know.
Lamons locations
Nozzle
Nov 20 2012, 12:23 PM
QUOTE(underthetire @ Nov 20 2012, 12:58 PM)
Thanks for the link Jeff. That's the first site I've seen that will sell individual gaskets. Looks like the smallest size they sell is too big for the fuel tank applications which are 8mm ID for the return and 10mm ID for the supply fittings. Sounds like I may have to go with the standard copper washers from AA if they don't make the Viton in smaller sizes.
scott_in_nh
Nov 20 2012, 01:06 PM
viton cuts easily - I made my own fuel tank gaskets from a small sheet of viton I procured from an engineer at work.
LotusJoe
Nov 20 2012, 01:24 PM
You can buy a bulk sheet.
http://www.mcmaster.com/#standard-viton-fl...gaskets/=k8z0xmOops, I just saw the price
a bit much for just making a couple gaskets.
Mikey914
Nov 21 2012, 01:20 PM
I can do this. And in some quantity these can be cost effective.
-Mark
Mikey914
Nov 21 2012, 01:35 PM
QUOTE(Nozzle @ Nov 20 2012, 10:23 AM)
What thickness? 1/8"?
Cap'n Krusty
Nov 21 2012, 02:53 PM
"Standard copper gaskets"? IIRC, they're fiber, not copper. Viton would crush, squeezing out and the connection would likely have a tendency to loosen over time. It needs a defined space to function properly.
The Cap'n
TheCabinetmaker
Nov 21 2012, 03:04 PM
Yes on the fiber washer. They are available at the bughaus.com for a few bucks each and work great. Just like the stock. Eric is a good guy and carries a lot of type 4 stuff.
TheCabinetmaker
Nov 21 2012, 03:06 PM
Oh yeah, he carries the strainer sock too.
Nozzle
Nov 22 2012, 09:33 AM
Thanks for the replies folks. Does anyone know if the fiber parts have problems with current fuel blends? I thought that was the idea behind the new Viton parts.
Cap'n Krusty
Nov 22 2012, 10:16 AM
Fiber don' care ........................
The Cap'n
Mikey914
Nov 23 2012, 08:44 PM
I had head that the OEM material was not as tollerent to ethanol. I'm doing some reasearch to see if they can be made inexpensively out of a more modern material, and at what cost. But only if the OEM ones are a problem. But from what I have heard here that may not be necessary.
Mikey914
Dec 13 2012, 01:24 AM
I have aquired 3 diferent grades of Viton and I'm conducting some testing to see how the material perform. Standard gas and E85. I'm interested as to how these will perform.
euro911
Dec 13 2012, 02:50 AM
I've just been VERY careful when dealing with the original ones. Interested in the outcome ...
