| aircraftdesign |
Nov 22 2012, 02:52 PM
Newbie ![]() Group: Members Posts: 13 Joined: 2-January 09 From: huntington beach, ca Member No.: 9,893 Region Association: None |
Regretfully, I'm selling..........
1971 914 originally a 1.7 but massaged to a 2.0 with same case. Rebuilt engine with a little more than break-in hours. Weber carbs now but all OEM fuel injection retained. New clutch, pressure plate, TO bearing, rebuilt (essentially new) calipers, rotors, struts, ball joints, rebutted & rebuilt pedal assy, new 19mm master cylinder, flushed and recoated gas tank, new electric fuel pump relocated to push from underneath the tank, new Tangerine stainless fuel line from tank to bulkhead, Optima battery, Blaupunkt radio, Fuch wheels, new Goodyear tires and new trim rubber and countless amount of labor hours (see pictures). OEM fog lights, switch and grilles included although not installed. $10k jgmhb@msn.com LINK to pelican where I posted a few pictures..... http://forums.pelicanparts.com/porsche-car...now-2liter.html Attached thumbnail(s) |
| aircraftdesign |
Nov 22 2012, 02:53 PM
Regretfully, I'm selling.......... 1971 914 originally a 1.7 but massaged to a 2.0 with same case. Rebuilt engine with a little more than break-in hours. Weber carbs now but all OEM fuel injection retained. New clutch, pressure plate, TO bearing, rebuilt (essentially new) calipers, rotors, struts, ball joints, rebutted & rebuilt pedal assy, new 19mm master cylinder, flushed and recoated gas tank, new electric fuel pump relocated to push from underneath the tank, new Tangerine stainless fuel line from tank to bulkhead, Optima battery, Blaupunkt radio, Fuch wheels, new Goodyear tires and new trim rubber and countless amount of labor hours (see pictures). OEM fog lights, switch and grilles included although not installed. $10k jgmhb@msn.com LINK to pelican where I posted a few pictures..... http://forums.pelicanparts.com/porsche-car...now-2liter.html Attached thumbnail(s) |
| aircraftdesign |
Nov 22 2012, 02:56 PM
| aircraftdesign |
Nov 22 2012, 03:01 PM
| aircraftdesign |
Nov 22 2012, 03:03 PM
| aircraftdesign |
Nov 22 2012, 03:05 PM
| aircraftdesign |
Nov 22 2012, 03:07 PM
| aircraftdesign |
Nov 22 2012, 03:16 PM
http://forums.pelicanparts.com/porsche-car...now-2liter.html |
| aircraftdesign |
Nov 22 2012, 03:18 PM
| billh1963 |
Nov 22 2012, 04:03 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Awesome car and damn good deal!
Don't forget to post interior pictures! |
| tangerinetea |
Nov 23 2012, 12:06 PM
Newbie ![]() Group: Members Posts: 3 Joined: 22-December 10 From: Florida Member No.: 12,510 Region Association: None |
Nice looking car with a lot of work put into it. Is the color then Canary Yellow (citronengelb aka lemon yellow) L11E?
Also, when you say a "massaged" 2.0 liter, do you mean rebuilt to stock 2.0 Liter spec's or something more? I am interested. Just want to know a bit more....' Thanks |
| tr709 |
Nov 24 2012, 08:55 AM
Newbie ![]() Group: Members Posts: 10 Joined: 7-October 12 From: Krugerville TX Member No.: 15,012 Region Association: Southwest Region |
Very Nice. How bout some interior pics?
| aircraftdesign |
Nov 24 2012, 06:24 PM
BTW - all of the inside sheet metal received Dynamat before the carpet and interior were re-installed.....and the pedals were rebushed Attached thumbnail(s) |
| aircraftdesign |
Nov 24 2012, 06:29 PM
BTW - all of the inside sheet metal received Dynamat before the carpet and interior were re-installed.....and the pedals were rebushed [/quote] Attached thumbnail(s) |
| aircraftdesign |
Nov 24 2012, 06:31 PM
| aircraftdesign |
Nov 24 2012, 06:37 PM
I'm trying to find the receipt for the short block who was done by a fella named Tuttle. Apparently, he is a air cooled guru who is well known for his Type IV head work. Once found I put in all the particulars beyond new bearings, pistons, cylinders, machine work etc.... especially as it relates to the heads. If I recall correctly he likes the 1.7 head to work his magic....
Happy Post Thanksgiving and now for SC ND game........... |
| aircraftdesign |
Nov 26 2012, 03:36 PM
I'm trying to find the receipt for the short block who was done by a fella named Tuttle. Apparently, he is a air cooled guru who is well known for his Type IV head work. Once found I put in all the particulars beyond new bearings, pistons, cylinders, machine work etc.... especially as it relates to the heads. If I recall correctly he likes the 1.7 head to work his magic.... 1.7 heads massaged with the following; 41mm Intake valves 34mm Exhaust valves 2.0 liter crank & rods 2.0 liter pistons & cylinder with heads opened up to accept the jugs - case left alone cam reground to work with Weber Carbs 8:1 compression .020" line bore new bearings throughout case plugged |
| aircraftdesign |
Dec 2 2012, 05:27 PM
re-installed a couple of trunk compartment pieces....
Inspection set up tomorrow for a potential European buyer and overall a lot of interest in the car - Thanks 914world / Pelican I thought I share - while putting together the paper work - I've assembled over $11K in receipts .............parts etc....... NO LABOR CHARGES whatsoever........... It seems that the more time I've invested in this, toward getting it where it is ..... the more $$$ lost based on the asking price........... For all those considering an undertaking such as this..... bringing an old car back to life........ it might be a more prudent move to look for a situation such as this.... where someone has already gotten a car to this point, because trying to do it yourself based on my experience is losing proposition....... outside of my love for old Porsche cars. I shouldn't have dug up all those receipts.........SIGH Attached thumbnail(s) |
| IGTARD |
Dec 10 2012, 08:55 AM
IGTARD ![]() Group: Members Posts: 27 Joined: 8-October 12 From: Left Coast Member No.: 15,013 Region Association: Southern California |
Sold? If you do this kind of work I'll be you client. shalom
| rhodyguy |
Dec 12 2012, 12:08 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
that's one clean car. bet someone could drive that one home.
k |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:59 AM |
