Seat ReUpholstery - Step by step, Here's how I did it |
turk22 |
Nov 23 2012, 08:56 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
I wanted to put together a little overview of my experience in Seat Upholstery.
I started with some very brittle and ripped seat and center cushion. I purchased my seat upholstery on ebay, but there are several vendors. Remove your seat, I did one at a time, in case I wanted to refer to the other seat to see how something was done. The first step is to remove the two screws on the back of the headrest Then the two screws in red behind the headrest flap There are three metal points at the base of the back rest that need to pry'ed up with a flat screwdriver and pliers to release the bottom of the backrest Here's the backrest removed, and you can see what it consists of on the back. On my car the headrest cover came off quite easy. Next you can see the points that hold the side bolsters on, these need to pryed up and straightened as well But first, you need to remove the seat rails by removing the 4 allen head bolts from each rail There are 2 metal points under the front seat, holding some tucked fabric onto the seat botton, release the fabric and straighten these points as well Now you release the points holding the bolster down, there are 10 or 12 on each side The bolster comes off like a jacket, and will go back on the same way |
FourBlades |
Nov 23 2012, 10:54 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Nice work! John |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:01 PM |
